Verify that a sum converges to particular function (Fourier Series)
GamesMasta
Verify the formula x=2*(sin(x)-(1/2)sin(2x)+(1/3)sin(3x)-...), {x,-Pi,Pi}
I guess, I am to show that the sum on the right converges to the function x. I began by rewriting the sum on the RHS as $\displaystyle\sum_{k=1}^k 2*\frac{1}{k}*sin(kx)(-1)^{k-1}$
Now, I'm not sure what I am to do next. Am I to take the limit of k to infinity? If so how does one solve that? Thank you!
Also, if one graphs this in Mathematica, it can be seen that as k becomes larger and larger the sin function becomes more and more like x through the origin between -Pi and Pi. I believe, however, that I am to show this algebraicly...
Do you know how to calculate Fourier series coefficients? I assume all you're supposed to do is verify that they match what you're given
Ah, yes I do! I was assuming that since the sum was written that was supposed to use that. I guess if I attempt to calculate the function with only sine terms the coefficients would be given by: b_{k}=\frac{2}{Pi}\int^{Pi}_{0}f(x)sin(kx)dx. You obtain (-1)^(k-1)(2/k) for the coefficient. This then gives you the Fourier Series that gives you the RHS of the original equation. But I am now to prove convergence? That is something I am having difficulty understanding. Any help would be appreciated.
Bump.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
