Viewing size of Galaxies 7 Billion light years away?
The discussion centers on the perceived angular size of galaxies 7 billion light-years away in relation to the universe's expansion. Initially, there was confusion about whether the angular size would appear doubled due to this expansion, but it was clarified that galaxies themselves do not expand; rather, it is the space between them that does. The perceived angular size of a galaxy depends on its actual size and distance, with calculations indicating that the angular size would not be significantly affected by the expansion of space. The conversation also touches on the 'turn over' in the angular size versus redshift relationship, noting that at certain redshifts, apparent sizes can vary. Overall, the impact of cosmic expansion on angular size is minimal for distant galaxies.
Remo Aviron
Would a galaxy 7 billion LY away appear to be twice the expected size (angular size) as a consequence of the expansion of the universe? (Assuming the universe is 14 Billion years old). My math says yes. But of course, I am just using trig and geometry. Just curious.
Astronomy news on Phys.org
I'm not sure how you are using that math, but the galaxy isn't expanding, just the distance between it and here. It would appear a size dictated by the actual size and distance to it.
Update and correction
Sorry, I messed up the math. It wouldn't be double. I know the Galaxies are not expanding. But the Universe is. Space is.
The question is how does the expansion of universe affect the preceived angular size of the galaxy? For example, if the galaxy were 100,000 ly across, you would expect it to occupy an angle of 0.0008 degrees. Does it occupy this angle, a smaller angle or a larger angle.
The space between galaxies expands so does the space within a galaxy, so probably you will not see the difference in angular size of that distance galaxy.
I think Remo Aviron is talking about the 'turn over' in the angular size vs redshift relation which occurs at about a redshift of ~1.65. If he/she is, then if we consider a standard ruler which has physical size 1kpc at a comoving distance of 1Mpc (0.003 billion LY), it will have an apparent angular size = 200 arcsecond. Moving this object to 7 billion LY (redshift =0.6), it will have apparent angular size = 0.15 arcsec, but moving it to reshift 6 (27.468 billion LY) it will actually have a larger apparent angular size when compared to the object at 7 billion LY, ie. apparent angular size = 0.17.
See http://www.atlasoftheuniverse.com/redshift.html" link for more information.
Well done, matt, I had a less delicate reply in mind. Scientists excel at discerning facts, politicians excel at manipulating them.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
