MHB Violet's Trigonometry Questions via Facebook
  • Thread starter Thread starter Prove It
    Trigonometry
The discussion focuses on solving various trigonometry problems using the sine and cosine rules. It demonstrates the application of the sine rule to find angles in triangles, specifically calculating the sine of angle β and using the cosine rule to determine angles in right-angled and non-right-angled triangles. The calculations include determining the lengths of sides and angles, such as finding the angle θ in an isosceles triangle and the area of a triangle using two sides and the included angle. The thread emphasizes the relationships between sides and angles in triangles, showcasing the importance of these rules in solving geometric problems. Overall, it provides clear examples of how to apply trigonometric principles effectively.
Prove It
MHB
1. By applying the sine rule we have
$\displaystyle \begin{align*} \frac{\sin{ \left( A \right) }}{a} &= \frac{\sin{ \left( B \right) } }{b} \\ \frac{\sin{ \left( \alpha \right) }}{10} &= \frac{\sin{ \left( \beta \right) }}{8} \\ \frac{\frac{2}{3}}{10} &= \frac{\sin{ \left( \beta \right) }}{8} \\ \frac{1}{15} &= \frac{\sin{ \left( \beta \right) }}{8} \\ \sin{ \left( \beta \right) } &= \frac{8}{15} \end{align*}$2. The length of the diagonal must be 10 units (it's a 3, 4, 5 right angled triangle magnified by a factor of 2 - check with Pythagoras if you'd like), so that means that the lengths from the centre to the vertices must each be 5 units in length.
Knowing this, the right hand isosceles triangle has lengths 5, 5, 6 and the angle between the two 5 lengths is $\displaystyle \begin{align*} \theta \end{align*}$, thus we can apply the cosine rule.
$\displaystyle \begin{align*} \cos{ \left( C \right) } &= \frac{a^2 + b^2 - c^2}{2\,a\,b} \\ \cos{ \left( \theta \right) } &= \frac{5^2 + 5^2 - 6^2}{2 \cdot 5 \cdot 5} \\ \cos{ \left( \theta \right) } &= \frac{25 + 25 - 36}{50} \\ \cos{ \left( \theta \right) } &= \frac{14}{50} \\ \cos{ \left( \theta \right) } &= \frac{7}{25} \\ \theta &= \cos^{-1}{\left( \frac{7}{25} \right) } \\ \theta &\approx 74^{\circ} \end{align*}$3. In $\displaystyle \begin{align*} \triangle ACD \end{align*}$ we can let $\displaystyle \begin{align*} \angle ACD = \theta \end{align*}$, then we can say that $\displaystyle \begin{align*} AD = \textrm{Opp} = 30 \end{align*}$ and $\displaystyle \begin{align*} CD = \textrm{Adj} = 40 \end{align*}$, so
$\displaystyle \begin{align*} \tan{ \left( \theta \right) } &= \frac{\textrm{Opp}}{\textrm{Adj}} \\ \tan{ \left( \theta \right) } &= \frac{30}{40} \\ \tan{ \left( \theta \right) } &= \frac{3}{4} \\ \theta &= \tan^{-1}{ \left( \frac{3}{4} \right) } \end{align*}$
Mathematics news on Phys.org
4. We have two sides and the angle between them, so we need to use the Cosine Rule.
$\displaystyle \begin{align*} b^2 &= a^2 + c^2 - 2\,a\,c\cos{ \left( B \right) } \\ b^2 &= 6^2 + 8^2 - 2 \cdot 6 \cdot 8 \cdot \cos{ \left( 120^{\circ} \right) } \\ b^2 &= 36 + 64 - 96\cos{ \left( 120^{\circ} \right) } \\ b^2 &= 100 - 96\cos{ \left( 120^{\circ} \right) } \\ b &= \sqrt{100 - 96\cos{ \left( 120^{\circ} \right) }} \end{align*}$5. The largest angle is opposite the largest side. You have all three sides of the triangle and are trying to find an angle, so you need to use the Cosine Rule.
$\displaystyle \begin{align*} \cos{ \left( C \right) } &= \frac{a^2 + b^2 - c^2}{2\,a\,b} \\ \cos{ \left( C \right) } &= \frac{6^2 + 5^2 - 10^2}{2 \cdot 6 \cdot 5} \\ \cos{ \left( C \right) } &= \frac{36 + 25 - 100}{60} \\ \cos{ \left( C \right) } &= \frac{-39}{\phantom{-}60} \\ \cos{ \left( C \right) } &= -\frac{13}{20} \\ C &= \cos^{-1}{ \left( -\frac{13}{20} \right) } \\ C &\approx 130^{\circ} \end{align*}$6. Again, we have all three sides and are trying to find an angle, so we need to use the Cosine Rule:
$\displaystyle \begin{align*} \cos{ \left( B \right) } &= \frac{a^2 + c^2 - b^2}{2\,a\,c} \\ \cos{ \left( B \right) } &= \frac{3^2 + 2^2 - 4^2}{2 \cdot 3 \cdot 2} \\ \cos{ \left( B \right) } &= \frac{9 + 4 - 16}{12} \\ \cos{ \left( B \right) } &= \frac{-3}{\phantom{-}12} \\ \cos{ \left( B \right) } &= -\frac{1}{4} \end{align*}$
7. To find the area of a triangle, you can use two sides and the angle between them.
As the three angles in a triangle add to $\displaystyle \begin{align*} 180^{\circ} \end{align*}$, that means the unknown angle must be $\displaystyle \begin{align*} 180^{\circ} - 30^{\circ} - 50^{\circ} = 100^{\circ} \end{align*}$.
$\displaystyle \begin{align*} A &= \frac{1}{2} \,a\,b \sin{ \left( C \right) } \\ &= \frac{1}{2} \cdot 6.13\,\textrm{m} \cdot 4\,\textrm{m} \cdot \sin{ \left( 100^{\circ} \right) } \end{align*}$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
11K
11K
11K
10K
