Voltage and electrode surface area
The discussion focuses on determining the minimum voltage required to initiate the electrolysis process in a brine solution using a graphite electrode. It emphasizes that while the minimum voltage is generally constant and not dependent on the electrode's surface area, the current produced is influenced by the surface area of the electrode. The minimum voltage for electrolysis of water is noted to be approximately 1.23 volts, although this value may vary under different conditions. Participants highlight the importance of understanding the relationship between voltage and current, with the consensus that while voltage remains stable, the current is affected by the electrode's surface area.
mksrm
TL;DR Summary
relation between minimum voltage and surface area of electrode
Hi
I am looking to find the equation that determines the minimum (and if possible maximum that might damage the electrode) voltage that starts the electrolysis process for a given area of a graphite electrode in a brine solution medium (lets say 30%) at equilibrium state.
Also how does the relation of voltage and maximum possible current to be applied be determined ?
Any help is greatly appreciated.
Chemistry news on Phys.org
Voltage is not electrode surface dependent. Current is.
mksrm said:
Summary: relation between minimum voltage and surface area of electrode
I am looking to find the equation that determines the minimum <<snip>> voltage that starts the electrolysis process
For the Minimum Voltage, the Wikipedia article is pretty good. And as Borek says, the electrode areas affect the current, not this minimum voltage:
Electrolysis of water requires a minimum potential difference of 1.23 volts, though at that voltage external heat is required from the environment.
https://en.wikipedia.org/wiki/Elect...r requires a,is required from the environment.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
