Voltage Confusion: What Am I Missing?
  • Thread starter Thread starter Jaccobtw
    Confusion Voltage
Voltage is related to the electric potential energy between charged particles, where decreasing distance increases voltage due to the inverse relationship in the equation V = k*q/r. While increasing distance does require more work to separate charges, it also means that the potential energy increases as the distance increases. The confusion arises from the distinction between voltage, which is energy per unit charge, and the work done in moving charges in an electric field. Understanding these concepts clarifies how voltage behaves in relation to distance and charge interactions. The discussion highlights the importance of grasping electric potential and its implications in electrostatics.
Jaccobtw
For two oppositely charged particles, does the distance between them increase or decrease voltage?
V = kq/r
I'm confused about voltage. According to this equation, decreasing distance would increase the voltage between two oppositely charge particles, but doesn't increasing the distance increase the potetnial energy between the two particles because the amount of work done would increase with distance, correct? It takes more energy to separate a charge a greater amount of distance increasing the voltage. Also the particles would have greater kinetic energy beginning from a larger distance.. What am I not understanding here? Thank you.
Hi,
Perhaps it helps to consider the electric potential field as energy per unit of charge.
And not talk of voltage between particles.
So a single charge ##q_1##, located at the origin of a coordinate system, has an electric field potential associated in space according to ##V = {k\,q_1\over r}##.
To bring a test charge ##q_2## (a second charge) from infinity to a position at distance ##r## from the origin requires an energy of ##q_2V =
{k\,q_1q_2\over r}##.
I.e. work has to be done to do this if the charges are of opposite sign.
[edit] OOPS! Someone should have jumped on this !
I.e. work has to be done to do this if the charges are of the same sign.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
