Volume of a object by being submerged
  • Thread starter Thread starter mikezietz
    Submerged Volume
The discussion revolves around calculating the volume of a rock submerged in water using its weight in air and apparent weight in water. The rock weighs 1400 N in air and 900 N in water, leading to an upward buoyant force of 500 N. By applying Archimedes' principle, the mass of the water displaced is determined to be 50 kg, which, when divided by the density of water, gives a volume of 0.051 m³. There is some debate over using 10 m/s² versus 9.8 m/s² for gravitational acceleration, but both approaches lead to the same conclusion regarding the volume. The final answer for the volume of the rock is 0.051 m³.
mikezietz
I have a multiple choice question where a rock weighs 1400 N in air and 900 N apparent weight in fresh water with 998 kg/m^3 density (i think), The question is what is the volume of the rock. 2 of the choices are .14 m^3 and .051 m^3. I have tried
p = m / v and 1400 - 500 and division by g's and densities, i have come too both of these conclusions many different ways, coming to either answer about the same amount of times. Does anyone know the true formula for this problem.
Well : 900 = 1400 - 500 that is OK. So let's take 10 for g, then the mass of the water that is moved by the submerged rock (you know, Archimedes' law) is 50kg. Divide this by the density of water and you get the volume that was moved, so this needs to be equal to the volume of the rock : answer 0.051...
marlon
why 10 for g, isn't g 9.8 and where does the 50 kg's come from
Well then take 9.8 for g...
500 N is the upward force and is equal to the weight of the replaced water. So you have that 500 = mg and if we take g to be 10, then m = 50
regards
marlon
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
