Volume of the solid of revolution
benedwards2020
Find the volume of the solid of revolution obtained when the region under the graph of
f(x) = \left( \frac{1}{x} \right) e^\frac{1}{x}
from x = 1 to x = 6
\pi \int (f(x))^2 dx
Ok, the equation I gave above should be that of a definite integral with a=1 and b=6 (If anyone can tell me how to write that in Latex it would be much appreciated)
So, the volume is
\pi \int_1^6 \left( \frac{1}{x} \right) \left( e^\frac{1}{x} \right)^2 dx
So, we can simplyfy this to
\pi \int_1^6 (x)^{-2} \times e^\frac{2}{x} dx
Now I'm a bit stuck as to where to go from here. Do I use the integration by parts method? I think I'm getting bogged down in unnecessary calculations. Can someone give me a hint or point me in the right direction?
Try setting u = 1/x or something like that.
?? You didn't finish your sentence! Between what limits? Rotated around what axis?
So you are rotating around the x-axis?
And only the region between x= 1 and x= 6?
So, the volume is
\pi \int \left( \frac{1}{x} \right) \left( e^\frac{1}{x} \right)^2 dx
No, If f(x)= \frac{1}{x}e^{1/x} then both f^2(x)= \frac{1}{x^2}e^{2/x}
With the values a=1 and b=6
\pi \int (x)^{-2} \times e^\frac{2}{x} dx
Okay, good. Now you have first x squared also. By the way, the code to put the limits of integration in is "\int_1^6". In other words, treat the lower limit as a subscript and the upper limit as a superscript on the integral sign.
Looks to me like the substitution u= 2/x should work nicely.
Many thanks for your time and help... I've managed to solve using substitution as you suggested.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
