A Vortex loop stabilization in SU(N) gauge theory - DBI term approach
vorker
TL;DR Summary
Can a DBI-type term stabilize vortons in SU(N) gauge theory? The curvature-dependent energy appears to balance line tension at a specific radius. Looking for feedback on whether this mechanism is physically sound.
I've been studying vortex solutions in SU(N) gauge theories with adjoint scalars. The standard problem is that vortons (closed vortex loops) are unstable and collapse due to line tension. However, I've found that including a DBI-type term (similar to those in string theory effective actions) might provide a stabilization mechanism.
The key point: the DBI term contributes an energy that depends on the extrinsic curvature K of the loop. For a circular vorton of radius R, the total energy becomes:
##E(R) = 2\pi R \mu + \frac{2\pi R}{\Lambda^4}\left[\sqrt{1 + \frac{\Lambda^4}{R^2}} - 1\right]##
where μ is the vortex tension and Λ is the DBI scale. The first term wants to shrink the loop, while the second term diverges as R→0.
Minimizing this gives an equilibrium radius:
##R_{eq} = \frac{\Lambda}{\sqrt{\mu \Lambda^4 - 1}}##
This exists when μ > Λ^(-4), suggesting a parameter regime where vortons are stable.
Has anyone encountered similar stabilization mechanisms for topological defects? Are there known issues with applying DBI terms in this context? Any relevant references would be helpful.
Can you give a reference that discusses such theories?
I can share a more detailed overview of the study with proper references. I just need a bit of time to tidy it up and make it presentable for the forum.
I'm not asking for your personal research. That's off limits for discussion here anyway. I'm asking for references that discuss the kinds of theories you mention and the "standard problem" you describe.
vortex solutions in SU(N) gauge theories:
vorton stability problem:
  • Martins & Shellard (1998) - https://arxiv.org/abs/hep-ph/9804378 - See page 2: "If a superconducting string loop has an angular momentum, it is semi-classically conserved, and it tries to resist the loop's tension... otherwise it is possible that dynamically stable loops form. These are called vortons—they are stationary rings that do not radiate classically"
The "standard problem" I mentioned is that vortex loops normally collapse due to their line tension. The established solution in the literature involves currents on the string creating angular momentum that balances this tension - as the Martins & Shellard paper states, this angular momentum "resists the loop's tension" and can lead to stable configurations. this approach has limitations.
The DBI-type approach I'm exploring would provide stabilization through a different mechanism - using curvature-dependent energy rather than angular momentum from currents. The reason I'm interested in this alternative is that it could provide geometric stabilization without requiring the strings to be superconducting. The DBI mechanism depends only on the loop's curvature, not on conserved charges that could potentially leak away.
Instead of relying on angular momentum from currents, I'm using the geometry itself. The DBI term makes the vortex energy depend on its curvature - essentially, the vortex becomes "stiffer" when you try to bend it too much. It's like the difference between a rubber band and a garden hose: the hose resists tight bending not because it's spinning, but because bending costs energy.
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
In LQG and LQC there are solutions called "black to white transition". I'll add some references: (Rovelli)https://arxiv.org/abs/1905.07251 (Rovelli)https://arxiv.org/abs/2302.03872 (Rovelli)https://arxiv.org/abs/1803.06330 (Rovelli)https://arxiv.org/pdf/1802.04264 (Rovelli)https://arxiv.org/abs/2108.12823 https://arxiv.org/abs/2304.02691 https://arxiv.org/abs/2110.07589 https://arxiv.org/abs/2009.01788 https://arxiv.org/abs/1911.12646 https://arxiv.org/abs/1801.03027...
Hello everyone, I am seeking to better understand the conceptual foundations and potential consequences of "Two-Time Physics" (2T-physics), as developed by Itzhak Bars and others. My interest was sparked by a recent paper that attempts to explain anomalous results in particle physics (apparent superluminal propagation of virtual photons) within the framework of 2T-physics: Paper: https://arxiv.org/abs/2408.02696 Key quote from the abstract: *"...the problem... can be solved naturally...
