Wall made of Pendulum -- thought experiment
In summary, a wall made of a pendulum or a ball attached to a string on top will not attract seismic forces, whereas a wall fixed solid will. If the wall is more flexible, it can deflect seismic forces.
Cobul
100
If your house wall is made of pendulum or a ball attached to a string on top. It won't attract seismic forces. Whereas if the wall is fixed solid. It can attract seismic forces.
What is the physics explanation of it? Is it because you try to deflect momentum or inertia? What is the right description to explain it?
What do you mean "attract" seismic forces?
That is not a meaningful word in that context.
Do you perhaps mean "susceptible to"?
Any would structure affixed to the ground,such as a wall, will be more susceptible to seismic tremors than something mechanically buffered, such as a pendulum, but pendulums don't make efficient walls.
I think you should elaborate on your question.
Likes russ_watters
What? Is "pendulum" a new element I've never heard of? What does a "wall made of pendulum" look like? And how do I insulate it?
Likes Vanadium 50
The pendulum is just metaphor for flexible wall. I reead that if a building is more flexibile. It won't attract much seismic force that when it is rigid. I just want to know how it deflects the energy. In the case of the wall using pendulum (just for sake of illustration). Why would the structure at least in the wall be less susceptible (if you want to use this language)? It's as if the pendulum or mechanical wall divert the momentum or inertia? I just want to know the physics description of it.
The mass of the building in conjunction with the restoring force of the springiness creates a mechanical resonator which is tuned below the main earthquake frequencies. It therefore presents opposition to fast movements. It can also be viewed as a mechanical high-pass filter.
In general, it's not so much about attracting vs. deflecting. It's more about dissipating the energy over shorter vs. longer time. Flexible structures store the energy and dissipate it over longer time, so the peak forces are smaller. In the case of oscillation you also need to avoid resonance with the driving frequency, so you need the right amount of stiffness vs damping.
One can also look at the problem as one of "coupling". If you mounted your building on roller bearing, for instance, the energy from the quake is not transmitted to the house and is, if anything, reflected away.
There is some impedance mismatch between a flexible building and a rigid earth. There is an even greater mismatch between roller bearings and a rigid earth.
Just taking your question at face value, I think it could be kind of interesting! Except I guess when you say "attracting [susceptible to?] seismic forces" it's more instead more meaningful to ask whether the structure would be subject to greater stress.
First, model the wall as either a vertical beam or a vertical plate. If the ground is subject to an acceleration ##\mathbf{A} = A_0 \cos{(\omega_d t)} \mathbf{e}_x## then you can model the situation by subjecting the structure to a uniform body force ##\mathbf{f} = - \rho A_0 \cos{(\omega_d t)} \mathbf{e}_x##. Taking the beam model as an example, this is equivalent to the problem of a horizontal cantilever beam, fixed at one end, and subject to a time-dependent gravitational potential ##U(y) = - \mathbf{f} \cdot \mathbf{x} = y \rho A_0 \cos{(\omega_d t)}##. Then you can just take the EL equation for the beam (assuming homogeneity of E and I)$$EI \frac{\partial^4 w}{\partial x^4} + \mu \frac{\partial^2 w}{\partial t^2} = q$$solve for ##w(x,t)## and from that determine the components ##\sigma_{ik}## of the stress tensor in the beam. Might be fun to try varying some of the parameters to see whether a flexible beam or a rigid beam will experience greater stress. [Maybe easier said than done, but hey, Mathematica exists for a reason!]
FAQ: Wall made of Pendulum -- thought experiment
What is a "Wall made of Pendulum" thought experiment?
The "Wall made of Pendulum" thought experiment is a hypothetical scenario that explores the concept of energy transfer and conservation. It involves a wall made entirely of pendulums, where each pendulum is connected to the next by a string. When one pendulum is pulled back and released, it swings forward and hits the next pendulum, causing a chain reaction of swinging pendulums. The question is whether the last pendulum in the chain will swing with the same force as the first one or if the energy will dissipate along the way.
What is the purpose of this thought experiment?
The purpose of this thought experiment is to illustrate the principles of energy transfer and conservation. It challenges our understanding of how energy behaves in a closed system and how it can be transferred from one form to another without being lost or gained.
What is the significance of a wall made of pendulums in this thought experiment?
The wall made of pendulums serves as a visual representation of a closed system, where energy can only be transferred between the pendulums and cannot escape. It also allows for a chain reaction of energy transfer, making it easier to observe and analyze the behavior of energy in this scenario.
What are some real-world applications of this thought experiment?
This thought experiment has real-world applications in fields such as physics and engineering. It can help in understanding the behavior of energy in systems like a row of dominoes, where energy is transferred from one domino to the next. It can also be applied in the design of energy-efficient buildings and machines.
Are there any limitations to this thought experiment?
Like any thought experiment, the "Wall made of Pendulum" scenario has its limitations. It is a simplified model that does not account for external factors such as air resistance and friction, which can affect the accuracy of the results. It also assumes ideal conditions, which may not always be the case in real-world situations.
