MHB Want to use probability algorithm for my web app
A freelance web developer is creating an answer filtering tool that poses six questions, with subsequent questions determined by previous answers. Each question offers 5-6 options, and the developer seeks to calculate the probability of each option's selection. The solution involves implementing binary concepts similar to electronic logic gates, where selected answers are represented as binary values. The developer is using Vuex for state management to ensure only the relevant question is visible based on user input. A free GitLab page will be shared for others to access this mathematical programming technique.
aaronsmith4
I'm a freelance web developer and right now I'm stuck into a mathematical(probability) issue where I'm developing an answer filtering tool.
This tool works as follows:
1) There are six questions that the user will be asked
2) Based on the answer of first question, my server will decide which should be the second question. Based on the answer of second question, the server will decide which should be the third question.
3) Each question has 5-6 options values
Now, for the six questions and each question has 5-6 options, what is the probability each options on my app? Is there any math equation to find out this? Once I solve the math logic, I would easily code the same.
Ok, I have found the solution, I'm going to implement the binary concepts to solve this issue. Just like the electronics logic gates. In these logic gates, zeros means the connection is closed and one means the connection is open. Scraped this and got the js code
Here in this algorithm, I have used to same. Once the user enters one condition and the equivalent question according to the selected condition will have the 1 binary value and all the other numbers will have zero binary value.
I have used Vuex for state-management. With Vuex, only questions with 1 input will be visible all the other questions will be invisible.
I will share the free gitlab page url so that anyone can copy this math programming trick and implement in their projects..
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
