- #106
- 8,938
- 2,946
harrylin said:1. The frame of the traveling twin is invalid for SR's laws of nature (even the second postulate doesn't work with it!).
That simple fact has also been elaborated many times on this forum.
What does "invalid" mean? The traveling twin's frame is not an inertial frame. It's not an inertial frame in GR, either. The second postulate states that the speed of light has speed "c" in any inertial frame. That doesn't mean that a noninertial frame is "invalid", it just means that the speed of light doesn't necessarily have speed c in that frame. You don't need a separate law to deal with a noninertial frame, you just need calculus. Calculus plus SR is still SR.
There is no such thing as a valid or invalid coordinate system. There is only valid or invalid reasoning. If you reason about a noninertial coordinate system as if it were inertial, then you've engaged in invalid reasoning.
So it is true that SR, when expressed as laws about inertial reference frames, tempts people into invalid reasoning if they try to apply the laws, as written, in a noninertial reference frame. That means that you need to understand what the laws say in a way that it is independent of coordinate systems. That was not completely understood at the time Einstein wrote SR. He did not know how to formulate laws that worked in any coordinate system. But that's a limitation of his mathematics, not his physics.
2. The frame of the traveling twin is valid for GR's laws of nature according to 1916 GR.
It's neither more nor less valid according to SR than GR. There is NO difference between SR and GR when it comes to noninertial frames. In the limiting case of flat spacetime, they are the SAME physical theory. You are perpetuating a misconception. That's my original point about Einstein's "GR solution to the twin paradox". It introduced a misconception that apparently persists to this very day.
