Washer Method and Shell Method setup issues
jonwill
Question)
A solid is formed by revolving the area inside x^(2/3)+y^(2/3)=a^(2/3), a>0; to the right of x=0 and above y=0 about the line x=a. Find the Volume of the solid using;
A) The washer Method
B) Cylindrical Shell Method
I am at a loss at how to set up this problem...I understand how to do the two methods once this problem is set up but I am just unable to do so.
I was able to solve for a and got a=(x^(2/3)+y^(2/3))^(3/2), but from there I am lost. I am new to the forum and only wished I had found it sooner. Everyone here seems very bright and knowledgeable.
Thanks for your time,
Jon
Welcome to PF!
Hi Jon! Welcome to PF! :smile:
(try using the X2 icon just above the Reply box :wink:)
Why are you solving for a? a is a constant :confused:
Both the washer method and the cylindrical shell method involve slicing the volume into easy-to-calculate regions.
The washer method uses "horizontal" slices, each has height dy and is shaped like a washer, ie it has an inner radius and an outer radius, so find the radii of each slice as a function of y, then find the volume (it will be a multiple of dy, the height), and integrate.
The cylindrical shell method uses "cookie-cutter" slices, each has thickness dx and is shaped like the round skin of a cylinder, so find the height of each slice as a function of x, then find the volume (it will be a multiple of dx, the thickness), and integrate.
What do you get? :smile:
Ok Thank you,
Solving for y:
y=(a2/3-x2/3)3/2
How would I plug this into the formula for the washer method? I get very confused when I am only given an "a" constant to work with instead of a solid number.
V=\Pi\intba((R(x))2-(r(x))2)dx
Hi Jon! :smile:
(have a pi: π and an integral: ∫ :wink:)
jonwill said:
Ok Thank you,
Solving for y:
y=(a2/3-x2/3)3/2
Isn't the outer radius always "a"? :confused:
And what are your limits "a" and "b" supposed to be?
And i see you're using dx …
what slice is dx the width of?​
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
