Water content in compressed air
Water infiltration in a newly installed natural gas main is causing freezing issues in the regulator and meter, likely due to moisture from compressed air during pressure testing. The user calculated water content at atmospheric conditions using a psychometric chart, estimating 9 lbs of water vapor. They seek to determine the water infiltration at 90 PSIG air, considering the ideal gas law and partial pressure. The discussion highlights the potential for significant water introduction from compressors, with examples showing a 10-hp compressor can add 7 gallons of water on a humid day. A link to further calculations was provided for additional context.
JackRuby
Hi-
A recently installed natural gas main is showing evidence of water infiltration. Water is getting into the customers regulator and meter and freezing. The gas main was cleaned and "pigged" after the installation. The system is currently operating at an MAOP of 60 PSIG natural gas.
When the main was pressure tested (at 90 PSIG - air) it is likely that water (in the form of vapor) got into the main from the compressed air (Air compressor).
Using a Psychometric chart I was able to calculate the amount of water at atmospheric conditions (14.7 PSIA). I assumed the Dry Bulb temp was 32 Deg, RH = 99%... etc.. Cameup with 9 lbs.
How would I calculate the water infiltration at 90 PSIG Air? I think I need to use partial pressure?
Any help would be greatly appreciated!
Via the ideal gas law, it would just be the ratio of the two air pressures: 90/14.7 * 9lb=55lb
? I was thinking of using the steam tables - partial pressure? What you are saying makes sense. Can you please confirm?
Thanks again!
JR
Thanks for the ideas...
I think I'm on the right track. The amount of water appears low. However, the actual pipe volume is very small. Still I've read that (for example) On a 75F day with 75 percent relative humidity, a 10-hp compressor can introduce 7 gallons of water into a compressed air system.
Instead of trying to type it all out here - I actually took the time to figure out how to use my free web space that is offered as part of my internet account. I posted the calculation there. Please forgive the very very crude looking web page. See link below.
http://home.comcast.net/~timbickford/htdocs/Water_Vapor_In_Pipe-Rev-1.pdf
Thanks..
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
14K
