B Water doesn’t fall in inverted half cup
  • B
  • Thread starter Thread starter Kashmir
    Air pressure Water
The discussion centers on the phenomenon of water not falling from an inverted half-filled cup, as demonstrated by Brian Cox. The explanation involves the development of negative pressure inside the cup due to paper deformation, which balances the atmospheric pressure outside. The gauge pressure created by the water is approximately 0.005 atm, requiring a slight expansion of air to maintain suction. Additionally, the hydrophilic properties of the paper and glass enhance surface tension, helping to keep the paper in place. The conversation concludes with a suggestion to devise experiments to further test this explanation.
Kashmir
I just happen to see a show about air pressure host by Brian Cox. As the link:https://i.stack.imgur.com/vfZlI.jpg shows, he flipped a half-filled water cup upside down then the paper on cup doesn't drop:
It puzzled me, because the cup is half-filled, the pressure shouldn't balance since inside water pressure+atmosphere pressure should be bigger than outside atmosphere pressure only.
What’s the explanation?
What does the film say?
The paper deformation will allow a negative pressure to develop inside the glass. The 5 cm of water in the glass will produce a gauge pressure of ~.005atm (10 m is one atm) so the air volume will need to expand by .5% to create that suction. In addition both paper and glass are hydrophyllic and the surface tension at the boundary will tend to retain the paper in place. Apparently the combination is enough.
Can you devise an experiment to test this explanation? I can think of two different ones.
Likes Juanda, vanhees71 and DaveE
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
