Water evaporation in semi-open system
In summary: If I add dry ice (a gas) to the bottle, what will happen to the vapor pressure of the liquid?The vapor pressure of the liquid will decrease.
TheFistGuy
Hello guys!
I'am having trouble getting my head around the physics of evaporation in quite specific situation.
So i have a closed container with opening in the bottom (cross-section in picture below). Let's say that water has a constant temperature of 80°C and container has a temperature 90°C, therefore the water cannot condense on the inner edges of the container. Outside the container is air with sea-level pressure.
So water evaporates and since vapor is lighter than air and it rises up. As it builds up in the container it should create some pressure (right?). Then due to the pressure the vapor should start escaping through the bottom (right?). So the first question is how much pressure is needed for the vapor to escape through the bottom?
And since vapor pressure builds up, that should slow the rate of evaporation. Is there any way to calculate this?
I will appreciate any help or links to related problems. Thanks!
What is the equilibrium vapor pressure of water at 80 C? If the pressure in the room is 1 atm, what do you think the total pressure in the "vapor space" within the container above the liquid water is?
At 80 C vapor pressure is 0.46 atm.
Pressure in the "vapor space" space should still be 1atm since it's an open system.
What does that tell me?
That tells you that the most that the average partial pressure of the water vapor in the head space can be at any time is 0.46 atm. The rest of the gas has to be air.
If the pressure outside the partially enclosed space is 1 atm, (assuming the opening isn't extremely small), then the pressure inside is 1 atm. I am not sure how the water remains 10° cooler than the container it is in, could you explain that (apparent) violation of the 0th Law of Thermodynamics? (Two objects in contact at equilibrium will reach the same temperature). While pressure is one way, and often used, to characterize a gas's composition, it is better here to consider that the key question is about the mixing of the air water gas with the atmosphere - which will occur around the opening. In real world conditions, the air-water mix will cool and water will condense into fog droplets and fall (there will also be some water vapor diffusion - unless the air is at 100% rh)
So if I get this right, then the only way vapor starts flowing through the bottom opening into atmosphere is if the vapor temperature is at least 100 C, i.e., water boils ??
The container is being heated. Therefore water will be few degrees cooler that container.
No, they certainly were not telling you that. The gases act independent of each other: as long as the partial pressure of water vapor in your container is higher than the partial pressure of atmospheric water vapor, water vapor flows out.
So far we have established that the composition of the vapor in the overhead space involves a mole fraction of water vapor of ≤ 0.46 and a mole fraction of air of ≥0.54 (all at 1 atm.). In the air outside, the mole fraction of water vapor is much less than 0.46 and the mole fraction of air is close to 1. So there is a concentration difference between the gas outside and the gas in the overhead space. Therefore, there is a mass transfer driving force for water vapor to exit the head space. Part of this the mass transfer (probably not much because the higher temperature is on top) can be by convection, so most will likely occur by diffusion in the tube. Knowing the diffusion coefficient, Fick's law can be used to determine the mass flow rate of water vapor. There is also heat transfer occurring by conduction occurring simultaneously within the tube. All this can be modeled.
And should not that be when vapor temperature is atlest 100 C?
Edit: ok no. Water vapor pressure in atmosphere is 0.023 bar at 20 C
Likes russ_watters
I have a related question but a bit different. Suppose I have a bottle of liquid (other than water - similar or low volatility). The bottle has a small opening (say 10 mm) on its top and wind blows over the top of the bottle. So, there will be pressure drop through the orifice or opening.
Is there any way to calculate for a given pressure drop what will be the evaporation rate?
Or let me rephrase the question -
Is there any method to determine rate of evaporation in a open system with surrounding pressure less than atmospheric (or maybe vaccum) ?
Related to Water evaporation in semi-open system
What is water evaporation in a semi-open system?
Water evaporation in a semi-open system refers to the process of water turning from a liquid state to a gaseous state due to external factors such as heat and air movement. It occurs in a semi-open system, where there is a limited amount of air circulation and the water is exposed to the surrounding environment.
What factors affect water evaporation in a semi-open system?
The rate of water evaporation in a semi-open system is influenced by several factors, including temperature, humidity, air movement, surface area, and the presence of other substances in the water. Higher temperatures, lower humidity, and increased air movement all contribute to a faster rate of evaporation.
What are the benefits of water evaporation in a semi-open system?
Water evaporation in a semi-open system plays a crucial role in maintaining the Earth's water cycle. It helps to regulate the temperature of the Earth's surface and provides moisture for the atmosphere. It also assists in purifying water by removing impurities and salt through distillation.
How does water evaporation in a semi-open system affect the surrounding environment?
The process of water evaporation in a semi-open system can have both positive and negative impacts on the environment. On one hand, it helps to regulate temperature and provide moisture, which is essential for plant growth. On the other hand, excessive evaporation can lead to drought and water scarcity in certain areas, impacting ecosystems and human populations.
Can we control or manipulate water evaporation in a semi-open system?
While we cannot directly control the process of water evaporation in a semi-open system, we can indirectly influence it through various methods. For example, by adjusting the temperature or humidity levels, we can alter the rate of evaporation. Additionally, we can use technologies such as fog collectors or condensers to capture and collect the evaporated water for various purposes.
  • Mechanical Engineering
  • Mechanics
9K
  • Mechanics
