B Water surface behavior under pressure change
When a compressed air vessel half-filled with water experiences a pressure drop from 10 bar to atmospheric pressure, the water surface remains largely stable due to water's incompressibility. The primary movement of the water is caused by the dynamic escape of air through an orifice, potentially creating ripples. Additionally, the vessel's contraction may cause the water level to rise slightly. If the water temperature is above 100°C, it may begin to boil, and dissolved gases will escape, forming bubbles. Overall, significant movement is minimal unless specific conditions, like temperature changes or prolonged gas dissolution, are met.
Bjott
Hi togehter,
this may be an easy one for most, but I'm really struggling with imagining the process.
Suppose we have a compressed air vessel that is half filled with water. The pressure in the vessel drops from 10 bar to atmospheric pressure within a few seconds. How does the water surface behave? Is there any movement due to the pressure difference? Or does the water only move due to the flow of the escaping air. Or is there no movement at all?
Thank you very much!
Welcome to PF.
I assume the reduction in pressure is due to loss of air only, not water.
Water is not really compressible, so the water volume will not change due to the change in pressure. The position of the surface should not change. The surface may be disturbed with ripples temporarily, caused by the dynamic escape of the air from an asymmetric orifice.
Likes russ_watters
It also may change due to changing strain in the pressure vessel itself. The pressure vessel will get smaller so the water will rise.
(Note, at this level you probably cannot consider the water to be completely incompressible either)
If the temperature happens to be above 100C (and below 160C), the water will start to boil.
Likes Bystander, russ_watters and Dale
If the water has stayed in this vessel with the high pressure air for a long period of time, then gas will dissolve in the water (at least, more than in atmospheric conditions). When the pressure is released the gas will escape again leading to small bubbles (also, already existing bubbles underwater will grow). Otherwise, not much movement as already pointed out.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
