I Water Waves Over Obstacles: Higher Frequencies Grow, Not Decay
Higher frequencies of waves generally dissipate more than lower frequencies, which explains why lower pitches travel farther in sound and why fundamental frequencies persist in vibrating strings and water sloshing. However, in shallow water waves, the opposite occurs when waves pass obstacles, leading to an increase in higher frequencies while lower frequencies diminish. This phenomenon is attributed to the wave's shape changing rather than a total energy increase, as the energy shifts from lower to higher frequencies. The restoration of wave shape after passing over obstacles indicates that the fundamental frequency remains unchanged, despite the distortion of the wave. Understanding this behavior involves recognizing the relationship between wave speed, depth, and frequency components in non-linear transmission media.
person123
TL;DR Summary
While higher frequencies seem to generally dissipate more than lower frequencies (e.g. sound waves, vibrating strings), the opposite is the case for shallow water waves: why might this be the case?
In general, it seems that higher frequencies of a wave dissipate more than lower frequencies.
For sound waves, it explains why you can hear lower pitches from farther away. For a vibrating string or plate, the higher frequencies also dissipate first, with the fundamental fading last. For water sloshing in a container (say a cup), the fundamental, main sloshing, is also what remains. In the case of light, the greater scatter of higher frequencies explain why the sky is blue (maybe this doesn't count because it's not really dissipation though).
There is an exception though -- traveling shallow water waves. It is well established (from experimental, field, and numerical work), that when a wave passes an obstacle like an underwater reef (and so energy is dissipated) the lower frequencies die out but the higher frequencies actually increase in amplitude. It's also sort of intuitive -- it seems reasonable that a sinusoidal water wave would get morphed into messier, higher frequency waves on passing an obstacle.
Why does this break the rule? Is there anything to get out of it being reversed?
For literature on this from the linked paper:
"Generation of higher harmonics in waves propagating over submerged obstacles has long been known. Johnson et al. (1951 ) noted that over natural reefs the energy was transmitted as a multiple crest system. Jolas (1960) carried out experiments with a submerged obstacle of rectangular cross section and observed that the transmitted waves were noticeably shorter than the incident waves. In an experimental study investigating the performance characteristics of submerged breakwaters, Dattatri et al. ( 1978 ) pointed out rather complex forms of the transmitted waves, which indicated the presence of higher harmonics. Drouin and Ouellet ( 1988 ) and Kojima et al. (1990) reported their experimental results with immersed plates, the latter emphasizing the phenomenon of wave decomposition and associated harmonic generation past the obstacle. Quite recently, Rey et al. ( 1992 ) have reported similar results for laboratory waves passing over a bar."
person123 said:
Summary:: While higher frequencies seem to generally dissipate more than lower frequencies (e.g. sound waves, vibrating strings), the opposite is the case for shallow water waves: why might this be the case?
The rule refers to the Energy in the wave. What changes with a surface wave in shallow water is the shape of the wave and that doesn't necessarily involve more total energy. The total energy in the wave consists of the height of the peaks and the motion in the troughs.
You can often see the sea waves regaining their shape after passing over a shallow reef but the height, once the original shape is established, will be less.
I agree the total energy will decrease. However, the energy also shifts from lower frequencies to higher frequencies. If you look at the PSD before and after passing, the intensity of the fundamental frequency decreases, while the intensity of the harmonics actually increase.
I wasn't aware of that (although that does seem right) -- that's good to know. If the shape is restored, I guess that means the energy must have shifted back to the fundamental frequency.
The fundamental frequency cannot change*; the change in wave speed gives a change (shortening) of wavelength. The transmission medium (water of finite depth) is not linear so (if you choose to analyse the wave shape in terms of its frequency domain) then you could say that harmonics will be generated. There is nothing to forbid those harmonics combining (interfere with each other) in a way that re- generates a regular, nearly-sinusoidal. wave on the way out.
It's not easy to understand this because the speed of surface waves depends on depth and wavelength. The basic waves are only approximately sinusoidal and so the speeds of the harmonics will change, relatively. So, once the depth changes significantly, the resulting wave shape will change as the fundamental component catches up with and overtakes the higher frequency products. (That suggests that ocean wave shapes will change as they progress; I could believe that.)
*Yes; the waves become more distorted but it’s not correct that there is a change in frequency. The time for a cycle has to be unaltered because there has to be continuity of phase across a transition.
That's how I have been looking at it. However, using the term "energy" could be misleading because what we really see is vertical displacement and the Impedance of the wave depends on the depth so it may involve no significant change in energy of the components because Energy relates to Displacement and Impedance.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
9K
