Water wicking up porous media and air humidity ?
The discussion focuses on how different configurations of porous media affect air humidity levels in a container. The consensus leans towards option #2 providing steadier and higher humidity, assuming the wick remains wet and energy is sufficient to remove water vapor. It highlights that water can rise more effectively through wicking than through air diffusion. The importance of air circulation is emphasized, as stagnant air can lead to saturation and halt evaporation. Overall, the effectiveness of each option depends on the balance between surface area, air exposure, and moisture dynamics.
Alfreds9
Hello,
I'd like to know which of these 3 example I sketched would have a steadier and higher air humidity at measuring point, assuming same conditions (except those illustrated as different, like porous media thickness and measuring point), water level and air turbulence within larger container (illustrations are a cross view).
Wild guesses are of course welcome since I don't need nor can ask for anything exact given my poor and generic example.
Thank you
Allison
Guessing - #2.
- assuming that the height up the sides is short enough to allow the "wick" to be wet at the top.
- there is enough energy to remove water from the wick at the top
- rule of thumb: water will climb higher via a wick than via diffusion in air.
Longer answer: it depends.
Likes Tom.G
Simon Bridge said:
Guessing - #2.
I see, thank you.
I erroneously thought it was #3 since I supposed the greater surface area of porous particles could play a role into replacing water vapor content in air more efficiently than porous particles slightly closer to measuring point.
The process is, simplistically, water evaporates off the top and gets carried off by convection (to be replaced by water from below kinda soaking upwards.)
If the top is not exposed to air that can circulate, then the air gets saturated so water no longer evaporates. This stops the process.
I suspect 1 and 3 would be about the same... the air in the narrow parts would quickly get saturated.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
