Waveguiding, Modes, Organic LEDs
Waveguiding in OLEDs involves the coupling of emitted photons into three modes: direct transmission, glass total internal reflection, and a guided mode in high-index materials. The estimated energy fractions for these modes are 0.2, 0.3, and 0.5, respectively. Techniques like random textures and microlens arrays are used to enhance output coupling efficiency by reducing total internal reflection. The thickness of the ITO layer is also optimized to minimize energy loss in the high-index mode. Understanding how photonic crystals facilitate the waveguiding of these modes is crucial for improving OLED performance.
needhelp87
Hi everyone,
I was wondering if someone could please explain to me the concept of
waveguiding, coupling/coupled, and guiding mode.
Here is an application of these terms:
The photons emitted in the active region of OLEDs are
coupled into three types of modes: direct transmission into
the air, the glass total internal reflection mode, and the highindex
~ITO/organic! guided mode. Assuming Lambertian
light sources, the fractions of energy in the three modes have
been estimated as 0.2, 0.3, and 0.5, respectively.2 A number
of methods have been suggested for increasing the output
coupling efficiency. For example, random textures or ordered
microlens arrays have been employed on the top surface of
the glass substrate in order to minimize total internal
reflection.3,4 The thickness of the ITO layer has also been
controlled in order to reduce the energy in the high-index
layer.5 An integrated classical and quantum-mechanical weak
microcavity theory has been proposed in order to calculate
the efficiencies of each mode for OLED layered structure.6
I don't really understand HOW a photonic crystal helps "waveguide" these modes OUT of the OLED? I appreciate your help. Thanks!
Source: pbg.kaist.ac.kr/pdf_text/yjlee03APL.pdf
^ Bump ^
Please, any help is appreciated. I have a presentation due in a couple of days.
Thanks.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
