Wavelengths of different colour of light
Different colors of light from the same source can raise the temperature of water at varying rates, with red light being more effective than blue light. The discussion highlights the relationship between light color and wavelength, suggesting that longer wavelengths, like infrared, are more efficient for heating. Participants shared resources for understanding the wavelength ranges of visible light. The conversation emphasizes the practical applications of different wavelengths in heating. Overall, the experiment illustrates the impact of light color on temperature changes in water.
s0610038
Hey guys
Today I've done an experiment and I found that when different color of light from the same light source (put of different color filter on the same light source) shine on a beaker of water, the temperature of the water will rise.
And different light will rise the temp of water in different rate. Such as red light will rise the temperature higher than the blue light, but here is the question
May I know that the wavelength of different colur of light?
Thanks
Science news on Phys.org
Look up visible light on wikipedia. It should give you approximate ranges for each color.
http://coolcosmos.ipac.caltech.edu/cosmic_classroom/classroom_activities/herschel_bio.html
Thanks for the link andy! It was interesting!
Thanks so much for helping
Well the use infra red for heating stuff don't they.
The longer waves seem to work best.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
