Waves, pulses, sound and things of that nature
The discussion revolves around solving a physics homework problem related to waves and sound. The user calculates the wavelength (λ) as 0.02 cm based on a diagram, and attempts to determine the wave speed (v) as 0.4 cm/s using the formula v = distance/time. They also relate frequency (f) to wave speed and wavelength, indicating a connection between these variables. The user expresses uncertainty about certain derivatives and values needed for further calculations, particularly in part 1b of the problem. Overall, the conversation focuses on applying wave equations and concepts to solve specific physics questions.
PhillipRussel
http://insight.ccsf.edu/file.php/4599/PDF/Exam1-Fall-2011.pdf
v^2=T/μ
κλ=2∏
ω=2f and many more
Starting with 1a the λ is 4/3*.015cm=.02cm since by the diagram the distance between the labeled point is 3/4 the wavelength
Now I'm not so sure about v. I don't think the diagram is used but in the given info in the statement. v=.3cm/.00075s right
And then the f is equal to v/λ right
I'll get to more later. I need to finish some astronomy homework real quick lol
for f may need to use displacement=2*pi*f*t or more exactly 0.3cm=2*pi*f*.00075s actually. what do you think
for 1b I am thinking dU/dx equals zero at (Xa,t1) and (Xb,t2). I'm still thinking about the other two. i know dy/dt=-v*dy/dx but am not certain of the values of dy/dt or dy/dx. I have a suspicion that dy/dx may be .5 at those other points.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
