- #36
Tournesol
- 804
MF said:I do not believe emergent properties are necessarily non-physical or non-computational. They may simply be perspectival.This is true only up to a point. Games of life (GoL) that we can conceive of are relatively simplistic. But imho it is possible in principle to have a GoL which is sufficiently complex that it does give rise to consciousness – as an emergent property within the game.
In what sense of "emergent" ? Would it then have properties beyond phsycial and computational ones.
In what sense of "emergent"? You use odf "perspectival" implies a weak, epistemic definition of emergence.
The weak forms of emergence are trivially true. But elsewhere you seem to think you ar deomstratig strong emergence.
No, it does not hinge simply on complexity. It hinges on perspective. Every “observation” assumes a perspective. 3rd person science assumes we can ignore (or compensate for) effects of perspective – but this assumption is an approximation and is not necessarily true under all conditions.Why would they be inaccessible ? Your argyument that conscious states of humans are inaccessible seems to hinge on their complexity. But whatever goes on in a GoL is comprehensible and predictable in principle, no matter how complex. Is this an in-principle inaccesbility, or an in-practice inaccessability ?Once this happens then it opens the door also to strong emergence – because there are properties of that GoL ... which
are in principle inaccessible from our perspective “on the outside looking in”.
It is necessarily true under phsyicalism as I define it , and it is necessarily true under the GoL.
The predictability of the GoL is predictability of it’s properties based on an external perspective (from outside the GoL) – there is no way, using data from an external perspective, to accurately predict the properties based on a perspective from within the GoL. It is an in-principle inaccessibility.
That doesn't follow at all. Everything about a perspective within the GoL is predictbale from an external
perspectve, including the limitations of an internal perspective within the GoL. Perhaps you mean there is no way, using data from an internal perspective, to accurately predict the properties based on a perspective from within the GoL.
But that boils down to epistemic limitation, and therefore to weak emergence.
3rd person science assumes that the influence of (literal) frames of reference can be compensated for.Subjective properties are bound up with (convolved with) the frame of reference. 3rd person science assumes properties can be measured independently of the frame of reference,If physicalism is true "frames of refernce" are as third-person comprehensible as anything else.But subjective properties ARE self-referential – by definition! That is precisely the reason why we cannot experience the same properties – because we have a completely different frame of (conscious) reference.
hence 3rd person science cannot be applied (in principle) to the explanation of subjective properties.
If they are irreducible. But if they are phsyicalism is false in the first place.
Not at all – you seem to be using a different definition of physicalism to me. I do not define physicalism to exclude 1st person subjective properties. Physicalism is the thesis that everything supervenes on the physical – it is NOT the thesis that all properties are explainable from a 3rd person perspective.IOW, there are irreducibly 1st-personal facts and phsyicalism is false. You seem to be trying to have your cake and eat it.I cannot know (exactly) what it is like to be a perceiving computer (any more than I can know what it is like to a bat) unless I actually BECOME a perceiving computer (or a bat)
"Everything supervenes on the physical" is a circular defintion of physicalism. I have arrived
at my version of by unpacking the meaning of "the phsyical". Do you have an alternative unpacking ?
Again, you seem to be using a very strange and restricted definition of physicalism which entails that everything must be comprehensible from a 3rd person. Could you provide a link to where you get this definition from?If physicalism is true, everything is entriely comprehensible, in principle, form a 3rd person POV, and it therefore doesn't matter where you start from.– but then by definition it wouldn’t be “me” knowing it – it would be the computer (or the bat). You simply “can’t get there from here”.
Perspective reduces to structure in a physicalist universe.It’s not simply about structure – it’s also about perspective –Originally Posted by TournesolEach “experiment” of consciousness is unique and different to every other “experiment” of consciousness, and there is no way in principle that we can precisely replicate one agent’s conscious experiment within another agent - because the precise make-up of the agent is one of the variables in the experiment. Simple as that. It’s all in the perspective. No new laws needed.
however unique it is. (Unless there are irreducibly 1st-personal properties, and physicalism
is f
alse).
that’s the point you are missing. Two identical agents (from a structural point of view) can have different perspectives because they occupy different positions and orientations in space. If you want to perfectly replicate an agent’s PoV, you must replicate it’s perspective as well as its structure.
And there is no barrier to that in a physicalist universe
No, computationalism does not imply such a thing (again unless you are using a very strange definition of computationalism). Computationalism is simply the thesis that cognition is a form of computation – it does not necessarily entail a 3rd person perspective comprehension of cognition.The wouldn't be if there are irreducibly 1st-persoanl properties, But computationalism implies that mentallity is entirely comprehensible, in principle, form a 3rd-person persepctive, since all computer programmes are.Computationalism isn’t in trouble at all. You just have to recognise that a perception implies a perspective – and there ain’t no way to get the true perspective of a “perceiving computer” from the perspective of a human being.
Not by itself, but no-one thinks computer oprogrammes have mysterious, irreducible
properties, so that follows on readilly.
Again, you seem to be using a strange definition of physicalism.By whose definition ? Calculating literal perspectives is just geometry. Physicalsim means everything is 3rd personal, including all "frames" and "perspectives".Just like there ain’t no way to get the true perspective of Q-Goest from the perspective of Moving Finger – it’s impossible by definition.
As opposed to what ? The claim that the physical is physical.
No it’s not, as shown above. Your definitions of computationalism and physicalism seem strange. Could you perhaps explain what definitions you are using?Yes it is , as demonstrated.None of this is at odds with computationalism.
I have.
"Physicalism says everything has only physical
properties.
Mathematics is the language of physics.
Therefore, physicalism says everything has only
mathematical properties
Mathematical properties are entirely objective and third-person.
Therefore, physicalism says everything has only proeprties that are entirely objective and third-person."Can you de-circularise *your* definition?
Where do you get this from?There are no irreducible perspectives under physicalsim and computationalism.There is nothing we have discussed here which cannot be explained based on a perspectival account of subjective perception.
"...Therefore, physicalism says everything has only proeprties that are entirely objective and third-person."
And what is this "physical" that everything supervenes on ?Not at all. Again, I’ll need to see your definition of physicalism, because I suspect it is different to mine. The thesis of physicalism simply says that everything supervenes on the physical – it does not say that things do not have “insides”, and it does not say that everything is comprehensible from a 3rd person perspective.If things have "insides" in some irreducible sense, phsyicalism is false.Remember that “not deducible” simply means “not epistemically accessible”. Just because I have no (epistemic) access to the “inside” of your consciousness (I cannot see the world precisely as you see it) does NOT mean that there are new laws of
physics at work,
Once again, physicalism does not entail that everything is comprehensible from a 3rd person perspective.According to whose principle ? According to physicalism there is such a way. Just understand Q Goest from a 3rd-person perspective.and it does NOT mean that determinism or reductionism (in the ontic sense) has failed. There is no way in principle that Moving Finger can see the world in exactly the same way that Q_Goest sees it,
It does accoreding to the only (non-circular) defintion so
far offerered.
The only central claim to physicalism is the thesis that everything supervenes on the physical. A “3rd person perspective account of all phenomena” is certainly not a central claim of physicalism.Once you have abandoned the central claim of physicalism, there is not much point worrying about the laws.What new physical laws? Don’t swallow the Chalmers’ hyperbole hook, line and sinker. There are no new laws, and none are necessary. Everything can be understood and explained based on “it all depends on your perspective”.
No, it's an implication.
