What a firecracker would do to a glass cub of water.
  • Thread starter Thread starter black phantom
    Glass Water
Exploding an explosive in a container of water that releases energy equivalent to vaporizing the water would likely result in the container being destroyed and water spraying everywhere. The rapid energy release would create extreme pressure, leading to an explosion, even if the container is sturdy. Microwaves could theoretically vaporize water quickly, but would also risk causing an explosion due to steam pressure. Using a strong closed container might allow for vaporization without immediate disruption, but this method is also dangerous and not advisable for home experimentation. Overall, the discussion emphasizes the risks and theoretical nature of such experiments.
black phantom
Hello,
I'm trying to figure out what would happen if you put an explosive into a container of water where the explosive released the same amount of energy it would take to vaporize the water in the container. What would happen to the container?
Normally, the energy required to vaporize the water would be spread out over a fair amount of time, even if you were boiling it at a very high heat.
If you caused all that energy to be expended at one time, I would assume that the water would end up mostly on the ceiling and the container would be inserted into the walls in small pieces except for the parts that were absorbed by your body.
You would then regret having done the experiment.
Ok, would there be any way to vaperise water in a container w/ a sudden burst of energy w/out disrupting the container? Maybe w/out a chemical explosive? So there is little expanding non water gasses, just the pure release of energy?
Microwaves. But unless you have an absolutely tiny amount it would require a huge burst. Much more than is safe to be around. And it is unlikely that the container would be able to survive the massive increase in pressure, so you'd still have an explosion, just from steam this time. Even an open container would probably be severely damaged unless it was very sturdy.
I have done this many times with my tea, and had to clean the mircrowave oven afterwards.
http://en.wikipedia.org/wiki/Superheating
The other way is to use a very strong closed container that can stand the pressure, and keeps the overheated water liquid, until you open it. But I'm not sure if you can get all the water to vaporize that way. And it is not a good idea to try this at home,
Ok, thanks everyone, you guys helped. And what I'm thinking about is not something i plan to do at home, its all strictly theoretical.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
