What am I doing wrong in solving 28/68=b^14 for b?
  • MHB
  • Thread starter goosey00
  • Tags
    Root
In summary: Doing so results in the following equation:f(t) = 21.693+68.93859 t^{\log_2}This equation can be solved for t using the quadratic equation, which yields the following:t = 1.8125+0.25871t^2This is the answer to the original question.
goosey00
37
The problem is 28/68=b^14 and I need to solve for b. I get .41176^14 which is not the right answer(which is .93859) What am I doing wrong?
Mathematics news on Phys.org
Hi goosey. First you simplify 28/68 which is about .41176. Then you must take that to the (1/14)th power, not to the 14th power. That's because opposites cancel each other out in a way.
If you have something squared and you take the square-root of it, the two things cancel and you just get the original number. \(\displaystyle \sqrt{5^2}=5\)
When working with higher powers, we you can use the reciprocal exponents to cancel out things. For the tenth power, \(\displaystyle \left( 4^{10} \right) ^\frac{1}{10} = 4\)
In our problem we have \(\displaystyle .41176=b^{14}\) and we want to find "b". So if we take both sides to the (1/14) power then the right side will simplify nicely.
\(\displaystyle .41176^{\frac{1}{14}}=\left( b^{14} \right) ^\frac{1}{14}\)
\(\displaystyle .41176^{\frac{1}{14}}=b\)
got it now. Ok, so the last part of this question my professor said do not find the solution as the book says by graphing. The final part of the problem is take f(t)=22+68(.93859)^t. He said to do it the way we learned through exponential and the answer is 21. Again, I must be off since I am not getting it right. The whole problem is taking Newtons law to find different temps. at different room temperatures.
f(t) represents a temperature after time "t", but we don't know what temperature we're looking for. We need to have a temperature before we can find at what time it reaches that temperature.
93 to 60 after 13 min in a room of 25 degrees. how long before it gets to 40 degrees. Although this is a different problem I am stuck at the same point. so far I have .49295 (1/13) which I got .94704. Now what is it do I do now w/out graphing to get it?
Hi goosey00, :)
Can you please clarify a bit more goosey. You have the equation, \(f(t)=22+68(.93859)^t\) where \(f(t)\) represents the temperature and \(t\) the time required to reach that temperature. What do you mean by,
And how did you obtain, \(.49295^\frac{1}{13}\) ?
Before I get even more confusing, Ill just post the last part on my teachers blog. Thanks for the response. I really appreciate it.
Another way to solve the original problem is to take the logarithm of both sides and use the properties of logarithms to simplify.
FAQ: What am I doing wrong in solving 28/68=b^14 for b?
What is the "root number" in science?
The "root number" in science refers to the fundamental or basic number that is used to represent a particular quantity or property. It can also be referred to as the base number or the starting point for calculations and measurements.
How is the root number determined?
The root number is typically determined through experimentation and observation. Scientists conduct experiments and collect data to identify patterns and relationships between variables. The root number is then calculated based on these findings and is used to represent the quantity or property being studied.
What is the significance of finding the root number?
Finding the root number is essential in science as it allows us to understand and quantify the natural world. It helps us to make predictions, solve problems, and make meaningful connections between different phenomena. Without identifying the root number, it would be challenging to analyze and interpret scientific data accurately.
Can the root number change?
The root number can change depending on the context and the variables being studied. In some cases, it may remain constant, but in others, it may vary. For example, the root number for a particular chemical reaction may change depending on the concentration of reactants or temperature.
How is the root number used in scientific equations?
The root number is typically used as a starting point in equations to represent a particular quantity or property. It is often combined with other numbers and variables to calculate or predict the value of a specific quantity. In some cases, the root number may also be raised to a power to indicate a relationship between different quantities.
