What amount of heat should be transferred to the gas
  • Thread starter Thread starter jbot2222
    Gas Heat
To determine the amount of heat transferred to a diatomic gas in a closed container to increase its pressure by a factor of 6, the process is identified as isochoric. The heat transfer can be calculated using the formula Q = n * Cv * (Tf - Ti), where Cv for an ideal diatomic gas is (5*R)/2. The temperature change (Tf - Ti) can be derived from the ideal gas law, leading to the equation Q = (25/2) * pi * Vi, where pi is the initial pressure and Vi is the initial volume. It is recommended to convert pressure to Pascals and volume to cubic meters for accurate calculations in Joules. The final expression provides a clear method to find the required heat transfer.
jbot2222
we haven't gone over this in class and its due for points and i have no idea how to do it...
A diatomic gas is confined to a closed container of volume 24.0m3 and pressure 3.03×105 Pa. What amount of heat should be transferred to the gas to increase the pressure by a factor of 6?
Is this all the data from the problem...?Don't they give you the mass of the gas,or any other piece of information?
Daniel.
nope, that's all that is given get. :bugeye:
isochoric or isothermic
with that data I can say it isn't an adiabatic or isobaric, the it could be isochoric or isothermic process. Do you know if you must get that final pressure with volume variation? or the volume is constant?
Some other stuff: if this is an ideal diatomic gas then the gamma coefficient (that is the division of caloric capacities for constant pressure and volume) is 7/5.
Surely the process with that data is isochoric, then the Heat Q that must be provided to system is, without a doubt:
Q=int(n*Cv*dt)
This integral must be evaluted for final temperature an initial one. If the gas is ideal, then:
Q=n*Cv*(Tf-Ti)
where n is the moles of gas Cv the molar caloric capacity at constant volume and Tf-Ti is variation of temperature.
For an ideal diatomic gas, the molar Cv is (5*R)/2 where R is the universal gas constant.
The variation of T must be obtained from the ideal gas state equation:
p*V=n*R*T
for the initial and final coordinates (initial pressure: pi, initial volume:Vi, final pressure: pf, final volume:Vf):
pi*Vi=n*R*Ti
pf*Vf=n*R*Tf
rest the first eq to the second one and you obtain:
(pf*Vf)-(pi*Vi)=n*R*(Tf-Ti)
or:
((pf*Vf)-(pi*Vi))/(n*R)=(Tf-Ti)
substitute this valour of variation of T in the Q expression and you will obtain:
Q=n*Cv*(Tf-Ti)
Q=n*((5*R)/2)*((pf*Vf)-(pi*Vi))/(n*R)
or reducing the terms in eq:
Q=5*((pf*Vf)-(pi*Vi))/2
since pf=6*pi and Vf=Vi (this is the data of your problem)
Q=(5*(5*pi*Vi))/2
Q=(25/2)*pi*Vi
the units are subjective, I recommend to use Joules instead of BTU or other energy and heat units. Convert the data you have (pressures und volumes) to the adhoc units, then substitute the values in the last expression. and you get the answer. if you want to get in Joules convert the pressures to Pascals and the volumes to m^3. since the units of pascal are N/(m^2), pressure times volume is N*m, that unit is J (Joule), then you can easily convert it to BTU or whatever unit you want.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
