What angle should the bird head?
To determine the angle a Canada goose should fly to maintain a direct southward path against a 34 km/h east wind while flying at 100 km/h, vector analysis is required. The calculation involves finding the resultant angle relative to the north-south direction, leading to an angle of approximately 19.9 degrees east of south. The discussion highlights the importance of understanding vector components and their application in real-world scenarios. Additionally, the flying speed of 100 km/h for Canada geese was confirmed as accurate. Mastery of vector concepts is emphasized for solving such problems effectively.
Junjou
Canada geese migrate essentially along a north-south direction for well over a thousand kilometers in some cases, traveling at speeds up to about 100 km/h. The one goose is flying at 100 km/h relative to the air but a 34 km/h wind is blowing from west to east.
At what angle relative to the north-south direction should this bird head to travel directly southward relative to the ground?
Set it up the following way and got about 70.1, subtracted that from 90 and got 19.9. Can somebody check my work to make sure I did it correctly?
Do you know anything about vectors?
We're currently learning vectors right now, but I've been struggling with it because of angles and the mess of formulas. I'm just not sure how to place the vector for the 100 km/h bird.
Looks like you got it.
Just in case you have to enter this in a computer or something: they ask for the angle wrt north-south, not for the angle wrt west...
I thought a flight speed of 100 km/h for a Canada goose was preposterous, until I looked it up... :))
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
