- #71
Hans de Vries
- 30
tiny-tim said:(Do you mean "an internal electron originates from the original electron but has a changed momentum {etc}"?)
Yes
tiny-tim said:I don't understand the physical meaning of "originates from the original electron".
"originates" how? where? and how/where does it de-originate?
It is the original electron field pertubated by the (alternating) photon field.
You have to think about the interaction of planewaves. The scattering zone
is considered wide enough to make this assumption valid.
tiny-tim said:And are you saying then that there is a physical internal electron for each internal electron line in each Feynman diagram (of which of course there are infinitely many) for the particular process?
In higher order diagrams there are electron and positron fields. Again, calling something
an electron and basing this on one of the quantization methods (electrons as
quantized excitations of the electron field) is something what you can do, or not do,
but it is not relevant for the end result. The pertubative series development is valid
with or without this interpretation of the individual terms.
tiny-tim said:And are you saying that there is a separate physical interference charge/current density between the original electron and each separate internal electron? And is there similarly a physical interference charge/current density between each pair of internal electrons?
No. The interaction is only with the photon which is connected to the interaction vertex.
tiny-tim said:Finally, what "incoming photon" (whose em field is to be negated)?
I didn't specify either an incoming or an outgoing photon in the interaction, and there doesn't have to be one!
There has to be a photon, either incoming, outgoing or internal (if you are restricting
this to QED).
Regards, Hans
