MHB What are the best resources for solving trigonometric equations and identities?
  • Thread starter Thread starter Amathproblem22
    Resources
For solving trigonometric equations and identities, users recommend utilizing resources like solved problems and comprehensive trig/pre-calculus textbooks. Engaging with textbooks allows for a structured approach, encouraging users to post questions as they progress. A specific resource shared is a link to a developed guide that helps streamline the learning process. These resources collectively support a better understanding of trigonometry. Effective study methods and community engagement are emphasized for mastering the subject.
Amathproblem22
As per the guidelines, I've come here to ask if anyone knows of any good resources regarding trigonometry. Mainly solving equations and identities.
Mathematics news on Phys.org
There are a lot of solved problems here. If that's not what you're after, you could get a trig/pre-calculus textbook and work through it, posting any question you have along the way. :)
Also check out this https://mathhelpboards.com/threads/trigonometry-to-memorize-and-trigonometry-to-derive.35/ that I developed. It can narrow down your efforts considerably!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
