What are the components of the vector
In summary, the boat traveled from the distress call point to the point where it was found by vector C = (40.6 km, -51.2 km), and the magnitude of this vector is 65.3 km.
anuman
I'm studying for an exam and can't seem to get this last practice problem! I've tried many ways but still keep getting the wrong answer. The professor has already given us the correct answer to the problems, but I want to know HOW to do it for the exam! Thanks in advance :)
A boat radioed a distress call to a Coast Guard station. At the time of the call, a vector A from the station to the boat had a magnitude of 45.0 km and was directed 15.0° east of north. A vector from the station to the point where the boat was later found is B = 30.0 km, 15.0° north of east.
12. What are the components of the vector from the point where the distress call was made to the point where the boat was found? In other words, what are the components of vector C = B - A?
x component y component
A)17.3 km, east 35.7 km, south
B)35.7 km, west 17.4 km, north
C)40.6 km, east 51.2 km, south
D)17.3 km, west 51.2 km, south
E)40.6 km, east 35.7 km, north
13. How far did the boat travel from the point where the distress call was made to the point where the boat was found? In other words, what is the magnitude of vector C?
A)65.3 km B)39.7 km C)26.5 km D)54.0 km E)42.5 km
Create a coordinate system with the origin at the Coast Guard Station. Use unit vectors of <x> in the east direction and <y> in the north direction. Then the vectors A and B can be expressed as
A = 45cos(75)<x> + 45sin(75)<y>
B = 30cos(15)<x> + 30sin(15)<y>
Then C = B - A is
C = (30cos(15) - 45cos(75))<x> + (30sin(15) - 45cos(75))<y>
The magnitude of C = sqrt( Cx2 + Cy2), where Cx is the magitude of the x component and Cy is the magnitude of the y component of the vector C.
Related to What are the components of the vector
What are the components of a vector?
A vector has two components: magnitude and direction. The magnitude is the length of the vector, while the direction is the angle at which the vector is pointing.
How do you find the magnitude of a vector?
You can use the Pythagorean theorem to find the magnitude of a vector. It involves taking the square root of the sum of the squares of the vector's components.
How do you determine the direction of a vector?
The direction of a vector can be determined by calculating the inverse tangent of the vector's y-component divided by its x-component. This will give you the angle at which the vector is pointing.
Can a vector have negative components?
Yes, a vector can have negative components. This is because vectors have both magnitude and direction, and negative components simply indicate a direction opposite to the positive direction.
Can a vector have more than two components?
Yes, a vector can have any number of components, depending on the system or problem being studied. For example, a three-dimensional vector would have three components representing the magnitude and direction in three different dimensions.
  • General Math
  • General Math
