What Are the Energy Levels and Degeneracies in a 3D Infinite-Potential Well?
  • Thread starter Thread starter freefallin38
    3d
The discussion focuses on calculating energy levels in a three-dimensional infinite potential well using the equation E=E0*(n1^2+n2^2+n3^2), where E0 is defined in terms of the particle mass and box dimensions. The third energy level is identified as degenerate due to multiple combinations of quantum numbers (n1, n2, n3) yielding the same energy. The user initially miscalculates the fourth level's energy, prompting a request for clarification on the correct approach. It is concluded that the fourth and sixth levels are also degenerate, similar to the third level, due to their respective combinations of quantum numbers. Understanding the degeneracy in these energy levels is crucial for further analysis.
freefallin38
For the third, fourth, fifth, and sixth levels of the three-dimensional cubical box, find the energies in terms of the quantity E0= π^2*hbar^2/(2mL^2), where m is the particle mass and L is the box's sidelength.
_____E0 (third level)
_____E0 (fourth level)
_____E0 (fifth level)
_____E0 (sixth level)
Which, if any, are degenerate?So the equation that I am using is E=E0*(n1^2+n2^2+n3^2), where n1, n2, n3 are energy levels. For third level, I used n1=1, n2=n3=2, so I got 9*E0. I thought that for 4th level I would just raise one level, making n1=n2=n3=2, and get 12*E0, but this doesn't work. Can anyone give me a hint as to what I'm doing wrong? Also, the third level will be degenerate, correct?
Don't forget about n1=3, n2=n3=1, and its permutations.
Do you understand why the 3rd level is degenerate? That will be necessary to determine which of the 4th, 5th and 6th levels might be degenerate also.
right, thank you! the third level is degenerate because you can have different wave functions, because you could also have n1=n3=2, and n2=1, and so on, right? Then the fourth and sixth levels would also be degenerate.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
