What are the equations for calculating loop currents in a circuit?
  • Thread starter Thread starter theuniverse
    Circuit Current
To calculate loop currents in a circuit, three equations are needed for the three unknown currents. The initial equations provided were incorrect, leading to erroneous current values. The correct equations involve considering the voltage drops across resistors accurately, particularly the contributions from all currents in each loop. After revising the equations, the correct loop currents were determined to be I_1=3.55A, I_2=-1.98A, and I_3=-2.98A. Understanding the voltage drop across each resistor is crucial for accurate calculations.
theuniverse
Find the Loop currents that are shown in the network of the figure below.
V=IR
I know that I need to create 3 equations since there are three unknown currents and then solve for them so here is what I got.
1) 10V-5I_1-2I_1=0
2) 10V-5I_3-3I_3-20V-4I_3+4I_2=0
3) 4I_2-4I_3+2I_2=0
When I solve for the currents I get
I_1=1.43A
I_2=-0.71A
I_3=-1.07A
While the correct answers should be 3.55A, -1.98A, -2.98A. I suspect that my equations are incorrect but I can't come up with any equations that give me the right answer or make any sense.
Thanks,
As you 'traverse' each resistive component in a given loop, you need to take into account all the currents flowing through that component. So, for example, the voltage drop across your 5Ω resistor is (I1 + I3)*5Ω.
Yea that was the concept I couldn't fully understand... I get it now.
In case anyone else is interested here are the equations that actually work:
1) 10V-5I_1-2I_1-5I_3=0
2) 10V -5I_1-5I_3-3I_3-20V-4I_3+4I_2=0
3) 4I_2-4I_3+2I_2=0
gneill You've been a great help as usual! Thanks!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
