What are the forces acting on a boat crossing a still lake at a constant speed?
A model boat with a mass of 25 kg is crossing a still lake at a constant speed, propelled by a force of 30 N. To determine the total friction force opposing the boat, it is noted that since the boat travels at constant velocity, the friction force must equal the thrust force of 30 N. For the buoyancy force, Archimedes' principle indicates that it must equal the weight of the water displaced, which corresponds to the weight of the boat due to gravity. Thus, the forces acting on the boat are balanced, with the thrust equaling friction and buoyancy equaling the weight of the boat. Understanding these forces is crucial for solving the problem correctly.
djstar
Hi could some one point me in the right direction for both parts of these questions, I am electrical biased so this is all new to me.
A model boat off mass 25 Kg is crossing a still lake at a constant speed, in a straight line. The engine is propelling the boat along with 30 force.
a) What is the size of the total friction force opposing the boat?
b) How much buoyancy force is the boat producing?
F=ma ?
a Sum Forces = mass * acceleration
b Archimedes Principle
for a) do i rearrange the formula and divide 30n/25kg = 1.2 m/s ?
for b) I now understand that the forces acting down must equal the forces acting up. does gravity come into this scenario?
a) Don't be silly. The problem asks what is the magnitude of the friction force opposing the motion of the boat. Ask yourself, if the boat is traveling at a constant velocity (it does not matter what this velocity is), what forces are acting on the boat? What must their magnitudes be relative to one another? You are given the thrust produced by the engine (30 N).
b) Obviously, if the weight of water displaced by the boat is equal to the weight of the boat, according to Archimedes, gravity is involved.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
