What are the forces involved in the following case?
  • B
  • Thread starter avito009
  • Tags
    Forces
In summary, Newton's first law of motion states that an object at rest will remain at rest and an object in motion will continue moving at the same speed and direction unless acted upon by an external force. In the example of playing catch, gravity is the external force that causes the ball to fall, but friction between the air and the ball may also play a role. This means that in this case, two external forces are involved: gravity and friction. The conversation also suggests that the speaker regularly shares their knowledge on the subject and is open to hearing additional insights.
avito009
184
Newton's first law of motion is often stated as. An object at rest stays at rest and an object in motion stays in motion with the same speed and in the same direction unless acted upon by an external force.
Now for example two people are playing a game of catch. The ball moves in the same direction and then falls down. so this external force must be gravity. But is friction between the air and the ball also involved?. Is friction also the external force? So in such a case two external forces are involved. One gravity and the other friction?
I always share my knowledge on PF. In most cases people add some more knowledge on the subject. Just wanted to check if I am right. Also do you have anything to add to this case?
Related to What are the forces involved in the following case?
1. What is the definition of force?
Force is a push or pull that causes an object to accelerate or change its motion.
2. What are the four fundamental forces of nature?
The four fundamental forces of nature are gravity, electromagnetism, strong nuclear force, and weak nuclear force.
3. How do forces affect the motion of an object?
Forces can cause an object to change its speed, direction, or shape. They can also cause an object to start moving, stop moving, or stay at rest.
4. How do forces interact with each other?
Forces can interact with each other by canceling each other out, adding together, or producing a net force in a certain direction.
5. What are some real-life examples of forces in action?
Some examples of forces in action are a person pushing a shopping cart, a ball rolling down a hill due to the force of gravity, and a magnet attracting a paperclip due to the force of electromagnetism.
  • Other Physics Topics
  • Classical Physics
  • Classical Physics
  • Classical Physics
