- #106
protonman
- 285
According to the scientific method the senses are assumed to produce valid perceptions. Since you don't even understand the mind you can not talk about valid and invalid perceptions.
Another unfounded statement.Originally posted by protonman
I don't have too (edit: don't have to show that logic is more valid than perception). All I said was that your method of investigation is not valid. If the method is not valid then the claims are not valid.
You have refuted nothing. You base your refutation on the scientific method which I have stated can not be used to establish valid knowledge.
Therefore, the results of your experiments can not enter as refutations of my statements.
protonman: According to the scientific method the senses are assumed to produce valid perceptions. Since you don't even understand the mind you can not talk about valid and invalid perceptions.
Zero: Another unfounded statement.
When are you going to get it through your head that we cannot even address your statements in a meaningful way if you refuse to demonstrate the reasoning behind your statements?
I attacked your view. It is up to you to defend it. That is all. There is no need for me to support logic or reason.Originally posted by Tom
You can say it all you want, it doesn't make it true. And you keep ignoring my point, which is that the method you are using (which you call "logic", but which I am sure is nothing of the kind) requires justification.
Something to consider, since this is a philosophical thread:Originally posted by ahrkron
The scientific method just uses the fact that perceptions are consistent among different persons, and that they yield repeatable outcomes. This, in turn, is an observation, not an assumption.
If you want to know inference is a valid perception because there are types of inferences that perceive an object exactly as it exists.
Inference can understand the relation between different phenomena and through understanding this relation something about a subtle phenomena can be understood through its relation to a gross phenomena.
For example, based visual perception a vase appears that it is not changing instant to instant. But from the point of view of logic it must be changing instant to instant. Why is this? Because if there were a moment it was not changing it would be permanent. If something is permenent and suddenly becomes permanent then you have a cause that arrises on its own. This violates cause and effect and those who accept this view have the burden of explaining why if cause and effect are not valid why do flowers not suddenly grow in the sky.
You also bear the responsibility to explain and rationalize your attack. I can say "The moon is made of green cheese. You are wrong to say otherwise.", and I have made an assertion. If that assertion is to be taken seriously, I must logically defend my point of view. There have been people who have been on the moon, and have found no green cheese. The moon does not appear to be green to any observer. The measurements of tidal forces and orbital mechanics show that a green-cheese moon would not be dense enough to behave in the way it does. Without a logical counter-argument, my position is properly ignored.Originally posted by protonman
The point everybody is making here is that you are NOT using logic or reason.
The only use of a thread like this is for me to clarify my own thinking and discussion skills...and it seems to be working rather well, don't you think?Originally posted by phoenixthoth
i can appreciate those sentiments, zero.
This violates cause and effect and those who accept this view have the burden of explaining why if cause and effect are not valid why do flowers not suddenly grow in the sky. [/B]
So far it has been quite a lousy attack.
ad hominem.
You would need to prove this. Not only that, but you would definitely need to quote in detail what you mean here by "perceive", "object" and "exists", since your assertion cannot hold for the common notion of perception.
why?
Unjustified assumption #1:
"if something does not change (even for a moment), it becomes permanent"
so what if it's unjustified? aren't all axioms unjustified?
I guess you meant "non-permanent" in the fist one. Didn't you?
If so...
Unjustified assumption #2:
"the character of 'being a cause' arises with 'permanency'"
Unjustified assumption #3:
"Dynamical evolution of a system cannot render it permanent"
It needs to be said also that no definition of "permanent" was given.
Unjustified assumption #4:
Violation of causality of the type "non-permanent transforms into permanent" allow for odd conclusions like the one provided for flowers in the sky.
[counterexample: self consistent systems can be developed in which causality is violated in restricted domains and which, nonetheless, display causal relations in many other realms; e.g., QM and its classical limit]
By definition that which is impermanent is changeing every instant.Originally posted by ahrkron
A permanent phenomena is an existent phenomena that does not change instantaneously.It needs to be said also that no definition of "permanent" was given.
If you accept that permanent phenomena can produce an effect you accept that a result can arise without a cause. IF this is so then you must explain why flowers do not arise in the sky suddenly or horns do not suddenly grow from my head. In other words, why is there a law of cause and effect.Unjustified assumption #4:
No cauality can never be violated in the physical world, by definition. All these ideas about time travel and string theory are mistaken. By definition a cause must preceed its result.[counterexample: self consistent systems can be developed in which causality is violated in restricted domains and which, nonetheless, display causal relations in many other realms; e.g., QM and its classical limit] [/B]
Look, I told you that I don't accept QM or anything after it. Why do you keep bringing it up.
My arguments appeal to reality, the world and experience. This is the only thing we agree upon.
It is really frustrating talking to people who are so dense.
You don't understand what I am saying so instead of asking you just come up with some pathetic attempt to refute it.
Do you know how long I have been thinking over these concepts. For over 7 years I have been contemplating the meaning of impermanence and I still don't understand it that well. ...
In a world obeying cause and effect there can not be a third class like the one you describe.That being the case, and given your assertion that "if there were a moment it was not changing it would be permanent", you still need to prove that:
1. nature does not contain a third class of objects, that change some instants, while remain unchanged the rest of the time; and
2. The vase is one of those.
You are wrong again, my young friend. If you cannot trust your mind, then you cannot trust your mind to judge who is wiser than you and who is not. How can you trust what someone tells you, when you cannot even trust what your senses tell you?Originally posted by protonman
Your minds are limited, my mind is limited. All we can rely upon is the testimony of those who have a greater clarity in their minds. Just as we see cars and tress and know they are real some people can see electro-magnetic fields and more subtle phenomena and understand them as obviously as we understand everyday objects. Until we reach the point where we can see all phenomena as easily as we see an apple in our hand we are no different than a blind person with a walking stick navigating a vast forest.
I am not saying that you can not trust any minds. What I am saying is that there are certain phenomena which are evident to us such as cars, trees and people. These exist, no question. But there are more subtle levels of existence which are not directly accessable via the senses. Therefore we must rely on logic. For example, if we see smoke on a hill we can infer that there is fire. Although we can not see the fire we know it is there. This is a valid perception through inference.Originally posted by Zero
Your "logic" negates itself rather neatly.
In other words, you are making things up as you go along. If you cannot trust the existence of what everone else agrees on, how can you assert the existence of things that have even less evidence to support their existence?Originally posted by protonman
I'm not making anything up as I go along. Everything I have said is self-consistent. Furthermore, I said I do accept things like trees and cars. I do accept what is conventionally agreed upon by all. How can you say I don't accept anything when I said I accept the existence of smoke?Originally posted by Zero
Again, by your own logic you cannot assert the existence of anything at all.
You amaze me as well as everyone here. How can no one criticize you for your statements. You say I don't accept anything. But in the post above I say I accept trees and such, no question. I go on to say that certain phenomena are not accesable via the sense and therefore we must rely on logic. The atom is a perfect example. It is beyond the range of the senses.Originally posted by Zero
