What are the Lorentz transformation tensors used for?
physicsforumsfan
Hi all,
I got a 3 part Qs: γ=1/√1-v^2-c^2
Part A
Consider the Lorentz transformation tensor
Matrix
Row 1: [ γ 0 0 -vγ/c]
Row 2: [ 0 1 0 0 ]
Row 3: [ 0 0 1 0 ]
Row 4:-[vγ/c 0 0 γ ]
for transforming 4-vectors from frame S to \overline{S} according to\overline{A}^{\mu} = L^{\mu} _{v} A^{v} . The coordinate system is x^{0} =ct, x^{1} = x, x^{2} = y, x^{3} = z .
Doing the transformation and then solving for it gives the answer:
d/d\overline{t}=γ(d/dt-vd/dx), d/d\overline{x}=γ(v/c^2 d/dt - d/dx), d/d\overline{y} = d/dy, d/d\overline{z}=d/dz
That's the answer I get but I am not sure about if I have the addition and substraction signs correct.
Part B
In above question, if the 4-vector potential is given by \underline{A}=(\phi/c, Ax, Ay, Az) in frame S what are its components in frame \overline{S}?
Again solving for and getting the answer, I am confused on the addition and subtraction signs:
\overline{A}=(γ\varphi/c + γv/c Ax, γAx+ γv\varphi/c^2, Ay, Az)
Part C
In Part B, the electric and magnetic fields are defined in frames S and \overline{S} by
E^{(3)}=-∇\varphi-dA^{(3)}/dt, \overline{E}^{(3)}=-∇\overline{\varphi}-d\overline{A}^{(3)}/d\overline{t}, B^{(3)}=∇xA^{3}, \overline{B}^{(3)}=\overline{∇}x\overline{A}^{(3)},
\overline{A}=(\overline{\varphi}/c, \overline{A}x,
If
\overline{A}y, \overline{A}z)=(\overline{\varphi}/c, \overline{A}^{(3)})
what is value of \overline{E}x?
Again solving for it I get my answer in which I am unsure of the addition and subtraction signs.
\overline{E}x=Ex, \overline{E}y=γ(Ey+vBz), \overline{E}z=γ(Ez-vBy)
I am also not sure if the have the vector components assigned to the correct axis.
Help would be appreciated.
Hi,
no reply?
Help?
From the PF rules - https://www.physicsforums.com/showthread.php?t=414380:
Do not "bump" one of your threads to the top of a forum's thread list by posting a basically empty message to it, until at least 24 hours have passed since the latest post in the thread; and then do it only once per thread.
Right Mark, thanks for telling me.
Just to clarify my questions, here is what I am trying to ask.
In Part A - I am supposed to find the transformation of the L matrix using that tensor equation. Is my transformation correct? It was my attempt at the question.
In Part B - Again, are the components of \overline{S} correct (ie. is \overline{A} correct)? It was my attempt at the question.
In Part C - It is a bit crowded (the formulae) but essentially they are the electric and magnetic field equations E, E (dashed), B and B (dashed) of the S and S (dashed) frames.
A (dashed, the 'if' was supposed to start before the A dashed equation and not in the middle)
I am supposed to find the E (dashed, the 'x' is a typo, sorry) components of this system (from the A dashed equation of part B). If the above is wrong then so is my following working. Are the + and - signs in the answer? It was my attempt.
Thanks
No Help?
Hey everyone,
Seems like another thread with no actual replies.
Just so I know, were the questions too hard or were they difficult to understand because of how I wrote them? I would like your honest opinion.
Thank you
physforums said:
Hi all,
Part A
Matrix
Row 2: [ 0 1 0 0 ]
Row 3: [ 0 0 1 0 ]
physforums said:
Hey everyone,
Thank you
Speaking for myself, I stopped reading about where I truncated your post. I'm not familiar with the subject and there are undefined symbols in the last line I left in. Perhaps if you posted this in a forum populated by more physics or EE types, you might find helpers who are familiar with the subject and notation.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
