What Are the Major Products of These Organic Addition Reactions?
The discussion focuses on predicting major products from organic addition reactions involving 2-ethylbut-1-ene with bromine and 1-phenylcyclohexene with H2O/H+. For the first reaction, participants analyze the bromide addition mechanism, with a consensus leaning towards 1,2-dibromo-2-ethylbutane as the likely product, emphasizing the importance of understanding reaction mechanisms and regioselectivity. In the second reaction, the addition of water leads to the formation of 1-phenylcyclohexanol, with discussions highlighting Markovnikov's rule and the significance of carbocation stability in predicting outcomes. The forum encourages deeper learning of reaction mechanisms rather than merely guessing answers. Overall, the conversation promotes a better grasp of organic chemistry principles.
devon
1. What is the expected major product arising from the reaction of
2-ethylbut-1-ene with bromine in carbon tetrachloride?
a. 1-bromo-2-ethylbutane
b. 2-bromo-2-ethylbutane
c. 1,2-dibromo-2-ethylbutane
d. 1,1-dibromo-2-ethylbutane
e. 1,1,2-tribromo-2-ethylbutane
Attempt: For this one I'm guessing C but I don't really know for sure.
2. What is the expected major product arising from the reaction of
1-phenylcyclohexene with H2O / H+ (catalyst)?
Select one:
a. no reaction
b. 1-phenylcyclohexanol
c. 1-phenylcyclohexane-1,2-diol
d. 2-phenylcyclohexanol
e. phenylcyclohexane
Attempt: For this one I get E as the alkene double bond will by hydrogenated. The double bonds of the aromatic system will not. Aromaticity is stabilizing. It's not reactive enough to react with H2.
You need to show a bit more effort than just randomly guessing one of the choices.
For the first one, can you talk about what type of reaction it is? What is the "key" intermediate which will determine the products? What factors affect the formation of the products from the "key" intermediate?
For the second question, why do you think that an acidified aqueous solution will hydrogenate double bonds? Can you tell us what you know about hydrogenation or alkenes as opposed o addition reactions (reagents, conditions, catalysts etc)?
Likes devon
Ok so I did a bit of study and got a better understanding of the topic. Bromide addition reactions that aren't aqueous (the tetrachloride isn't used, just to identify that it's not in water) "break" the double bond and replace either side of it with Bromide ions. So for 1. I would go with C as 1 bromide ion would go on the first carbon (replacing the double bond) and the 2nd bromide would go on the 2nd carbon (replacing the double bond).
For 2. I studied Markovnikov reactions and found that it's similar to the bromide reaction above except that it "replaces" the double bond with an hydrogen and a hydroxide. With that information I choose B as the addition of the OH functional group will make it an alcohol (the hydrogen doesn't really change anything name wise) and because the phenyl will still be connected (Is there any way to figure out if the Hydrogen or the OH is the one connected to the phenyl carbon (carbon 1) or is it random/ unpredictable?
Hope that's the kind of explanation you're looking for! Thanks for making me look it up, I learn much better that way.
I agree with your answer but I would advise you to learn the mechanism and work through it. Most importantly to learn what the key intermediate is and why a certain product may be formed instead of another. Your answer, I believe, is correct but the question is relatively straightforward. Instead of thinking about the products and reactants, learn to work through the mechanism of the reaction. This particular reaction can get tricky quickly if you don't know how to work through the mechanism if you need to start thinking about regioselectivity and stereochemistry.
Take a look through this link.
There most certainly are models to predict which carbon will get the proton and which will be attacked by water. Again, I suggest you learn the mechanism and get a handle on the trends of carbocation stabilities. I never liked the whole Markovnikov and such addition thing. These questions can all be worked out by understanding a few basic principles and working through the mechanism to determine intermediate stabilities and predict the products.
See Wikipedia for hydration reactions and http://www.chem.ucla.edu/harding/tutorials/cc.pdf for carbocation stabilities.
Yes that was much better. I hope you understand we are not trying to be mean, it is the policy of this forum to guide people to find the answer themselves instead of just solving the problems for you.
Thank you so much for your help, I'll definitely make sure to look at the actual chemistry behind these reactions! So I assume because you didn't say anything that my answer for 2 1-phenylcyclohexanol (b) is correct?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
