I What Are the Physical Properties of Human-Sized Worm Holes?
Unbreakabletoon
TL;DR Summary
Worm Hole Theoretical question. Worm hole physical properties.
Hello Everyone in the forum:
I have a theoretical question about Worm Holes. So for the sake of this question let's just assume we have the technology and the power source to fire up a small human size worm hole. My question would be regarding the edge of the worm hole. Would you be able to touch the edge or would the worm hole be more like a fourth dimensional sphere? (since it is connecting space by folding it on a higher dimension). However, if you were able to actually touch the edge would it be solid or would it be infinitely sharp?
The wormhole doesn't have an edge. It blends continuously into the surrounding spacetime.
Neither.
This is a common pop science description, but it has nothing whatever to do with actual mathematical models of wormholes. In the actual mathematical models, spacetime is just a 4-dimensional continuum; it's not embedded in anything higher-dimensional. In spacetimes with wormholes, the continuum is multiply connected, but that can be described entirely in terms of properties within the continuum, without having to make use of any embedding in anything higher dimensional.
A wormhole would seem to someone traveling through it like empty space, which has neither of these properties.
Thank you. Can you recommend any books in the subject? :smile:
Likes kent davidge
Not books, but the original wormhole paper by Morris & Thorne is worth reading:
http://www.cmp.caltech.edu/refael/league/thorne-morris.pdf
Likes Klystron
Likes Motore and Ibix
Thank you very much for your time. I had the feeling most Hollywood movies had this wrong. I started thinking about this and wasn't able to find a specific answer in most articles I read.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
