What are the properties of lithium gas?
The discussion centers around the properties of lithium when it transitions from a solid to a gas. It is clarified that, unlike water, which retains its molecular structure as H2O in all states, lithium's properties change significantly when it becomes a gas. Key properties such as malleability, density, and conductivity are lost in the gaseous state. The original inquiry stems from an interest in battery technology, specifically how lithium functions as an anode and whether energy can still pass through gaseous lithium if it is dense enough. However, participants express concern that the initial question reflects misconceptions about physics and chemistry, suggesting that a foundational understanding of these subjects is necessary for meaningful discussion. They recommend studying basic physics and chemistry to clarify these concepts and facilitate better communication.
ARC123
I know this may be a dumb question but I don't know it. What I want to know is when lithium is heat and becomes a gas/vapor, does it still have the properties of lithium. Also I know that when water is changed between a liquid, gas, and solid, it always stays as H2O on the molecular level, can lithium or other material do the same?
Chemistry news on Phys.org
Which properties? It is a gas now, so it doesn't have malleability, also its density and conductivity (and zillions other things) have changed.
Sorry my bad I keep forgetting to add all the important information. I was originally looking into how batteries work. I was doing some research on the anodes and cathodes and how they work. I found that lithium is a anode, then I had and ideas. Now since I don't fully understand how the anodes and cathodes move energy I don't know if this is possible. My idea was if you heated lithium to the point it becomes a vapor/gas and make it dense enough, will energy still be able to pass through it the same way it does it in a battery. So when I said property, I was trying to say can it still have energy move through it if it is dense enough.
I am afraid your post is riddled with misconceptions to the point where it is impossible to address.
Not even sure what you mean by "moving energy".
I feel like you may need a primer in physics and chemistry, otherwise you will be wasting time chasing some erroneous ideas.
Likes Nidum
Thanks for helping. The only reason I asked this on here was because I am not taking physics yet and I have questions that I want answered.
No problem - but if so I would suggest getting some basic physics and chemistry books and trying to learn from them, we will be happy to help. You need some basic understanding of the nature physical and chemical of things and some basic understanding of the language used to talk about them. Otherwise we will end frustrated on both sides - we, as we wouldn't be able to help, you, as you wouldn't be able to understand.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
