MHB What Are the Steps to Simplify Algebraic Expressions?
  • Thread starter Thread starter eleventhxhour
    Simplify
To simplify the expression -2x[5x-(2x-7)]+6x[3x-(1+2x)], first simplify the inner components: 5x - (2x - 7) becomes 3x + 7, leading to -2x(3x + 7) = -6x^2 - 14x. Next, simplify 3x - (1 + 2x) to get x - 1, resulting in 6x(x - 1) = 6x^2 - 6x. Finally, combine the two parts: -6x^2 - 14x + 6x^2 - 6x simplifies to -20x. The final simplified expression is -20x.
eleventhxhour
How do you simplify this?
$$-2x[5x-(2x-7)]+6x[3x-(1+2x)]$$
Can someone show the steps? I keep getting the wrong answer.
Mathematics news on Phys.org
I would first simplify the inside pieces, multiple, and then add. That is,
5x - (2x - 7) = 5x - 2x + 7
Correct?
Then we have
Now for the other piece, we have
3x - 1 - 2x = x - 1
Correct?
Then we have
6x(x-1) = 6x^2 - 6x
Now we can add the two pieces together to get
-6x^2 - 14x + 6x^2 - 6x = -20x
This is practically a duplicate of a previous question. You were given plenty of reponses. If you didn't understand you should have asked for clarification, although expanding brackets is so fundamental you will be able to find step by step guides in any textbook on secondary school algebra.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
