What are the units for Molar Mass in Chemistry and Physics?
  • Thread starter Thread starter SAT2400
    Unit
The unit for molar mass can be expressed as grams per mole (g/mol) or kilograms per mole (kg/mol), depending on the context. In chemistry, g/mol is commonly used, while physics typically uses kg/mol as the SI unit. Both units are acceptable, and the choice often depends on the specific problem or teacher's preference. It's important to ensure that units are consistent and properly converted when necessary. Ultimately, there is no single "correct" unit for molar mass; it varies based on the discipline and context of the question.
SAT2400
Unit for Molar Mass(M)??
What's the unit for Molar mass? Is it different in CHemistry and Physics?
PV=nRT
In Chemistry class(last year) I think I used (g/mol).
But in Physics, my teacher says it's (kg/mol).
What is right??
THanks
PV=nRT
What is right??
THanks
In Physics, the SI unit for mass is the Kg. In chemistry, it usually is grams but it also depends on the type of questions you do and what S! unit the question asks for.
g/mol, kg/mol, slugs per mol, and (whatever other mass unit) per mol are all fine for both physics and chemistry. However, it may be more convenient to use a certain unit for certain calculations.
It is like asking which is a 'correct' pressure unit - PSI, atm or Pascal.
In your assignments and tests, use whichever you feel more comfortable with. Then just convert the answer to the units your teacher wants. There is no "correct" unit here, just your teacher's personal preference.
If you are careful to always make sure your units check out and cancel properly, there should be no problem.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
