What can be said about S-T global properties from the EFE?
In summary, the conversation is discussing the definition of spacetime in the context of general relativity. The speaker argues that leaving aside certain physical conditions, there is no strict grounds to discuss global properties of spacetimes like singularities. They mention the singularity theorems of Hawking and Ellis as being part of the math of GR, and suggest taking a look at their definition of singularities. The conversation then shifts to discussing the age of Hawking and Ellis' book and the need to update the bibliography. The speaker also mentions the need to assume that a Lorentzian manifold is time-oriented to be considered a spacetime and questions the mathematical requirements for this assumption.
loislane
134
In another thread I was arguing that leaving aside reasonable physical conditions that are added independently from the math of GR, [wich I consider basically the EFE, the EP, general covariance and the metric and curvature tensors in the neighbourhood of points that solve the EFE in the context of background independence from any fixed geometry that might be inferred], there is no grounds strictly to discuss about global properties of spacetimes like singularities other than as informed speculations based on what subjectively one might consider to be reasonable physically or more pleasing aesthetically or more convenient under certain particular coordinates but certainly not as something derived from the math of GR by the inherent locality of the EFE solutions determined by the absence of an absolute spacetime of constant curvature like in the Minkowski case in SR and the fact that the symmetries in GR are determined by the Diif group of GR, i.e. invariance under arbitrary local changes of coordinates .
Any commnets to the points above?(please be specific)
see for instance http://physics.stackexchange.com/questions/111670/global-properties-of-spacetime-manifolds for background
What exactly is your agument?
It seems that you are saying that most of Hawking and Ellis' book is just informed speculations based, any any of the global results since the 1960's.
This is too narrow a definition, at least the way GR is actually done. The way GR is actually done certainly includes global methods, such as those in Hawking & Ellis, as martinbn mentioned. That reference goes into excruciating detail about singularities, precisely because the global properties of solutions that have are of great interest (since those solutions include the FRW solutions of cosmology and the black hole solutions). So I don't see the point of limiting "the math of GR" to purely local properties; that's not all we use GR for.
The singularity theorems of Hawking & Ellis, which are certainly not "informed speculations" but rigorous mathematical results, are, as I said in my last post, certainly considered part of "the math of GR" by workers in the field. I suggest taking a look at Hawking & Ellis and their definition of what it means for a spacetime to contain a "singularity". The basic point (which has been made in multiple prior threads on this topic) is that singularities are not defined as "places where curvature blows up" or something like that; they are defined in terms of geodesic incompleteness--the existence of geodesics in the spacetime that cannot be extended to or beyond some finite value of their affine parameter. A common reason for geodesic incompleteness is that some invariant quantity evaluated along the geodesic diverges in the limit as some finite value of the affine parameter is approached. However, it is geodesic incompleteness, not the divergence of any particular quantity, that defines the presence of a singularity.
So Hawking and Ellis book is more than 40 years old and it seems even their definition of spacetime(for curved Lorentzian manifolds that is) has been modified by slightly more recent books like "Global Lorentzian geometry" by Beem, Ehrlich and Easley. It might be a good time to update the bibliography a bit.
In H&E definition any pair M, g with g a Lorentzian metric is considered a spacetime but it seems to me that just with that basic starting point it is not possible to prove things like the initial value proble being well posed and the existence of a globally hyperbolic manifold in GR. So nowadays one needs to assume that a Lorentzian manifold must be time-oriented to be called a spacetime.
Now, I would like to get a better grasp of the math requirements in order to assume that a general Lorentzian manifold is time-oriented, that is for admitting a continuous, nowhere vanishing timelike vector field in the presence of curvature..
Really? Can you give specifics? I wasn't aware that anyone's "definition of spacetime" had been modified.
Of course not. Those proofs require additional assumptions, and H&E are quite clear about what those additional assumptions are.
Just as a note, time orientability is not a sufficient condition for the other properties you named. As is discussed, IIRC, in H&E.
In any case, AFAIK restricting the term "spacetime" to time orientable manifolds only is not a mainstream use of language.
IIRC, H&E go into exactly this in quite some detail.
FAQ: What can be said about S-T global properties from the EFE?
What is the EFE and how does it relate to S-T global properties?
The EFE, or Einstein field equations, are a set of equations that describe the relationship between the curvature of space-time and the distribution of matter and energy. They are used in the theory of general relativity to understand the behavior of objects in the universe. By solving the EFE, scientists can make predictions about the global properties of space-time, such as its curvature and the presence of gravitational waves.
Can the EFE be used to determine the shape of space-time?
Yes, the EFE can be used to determine the overall shape of space-time. This is because the equations describe how the curvature of space-time is affected by the distribution of matter and energy. By solving the equations, scientists can determine the overall geometry of space-time, which can be flat, curved, or even warped.
How does the EFE help us understand the expansion of the universe?
The EFE can be used to model the expansion of the universe. By plugging in different values for the distribution of matter and energy, scientists can determine how the universe would expand over time. This has been used to support the theory of the Big Bang, as well as to study the effects of dark energy and dark matter on the expansion of the universe.
What can the EFE tell us about the presence of black holes?
The EFE are crucial in understanding the behavior of black holes. By solving the equations, scientists can determine the curvature of space-time around a black hole, as well as how it affects the motion of objects and light. The EFE also predict the existence of event horizons, the point of no return for anything entering a black hole.
Can the EFE be applied to other areas of physics?
While the EFE were initially developed to describe the behavior of gravity and space-time, they have also been applied to other areas of physics. For example, the equations have been used to study the behavior of matter at the atomic and subatomic level, as well as in the study of cosmological phenomena like the formation of galaxies. They have also been used in the development of theories like string theory and loop quantum gravity.
