I What can be used as a Frequency generator to make Chladni patterns?
  • I
  • Thread starter Thread starter gavinthoms
Chladni patterns can be created on a resonant plate by exciting it with a small hammer, a violin bow, or an electronic oscillator adapted with a speaker coil. Finding the critical resonant frequency can be challenging with electronic oscillators. An alternative method involves using a small electric motor with an unbalanced shaft to shake the plate at its rotation speed. A vibration generator paired with a signal generator and audio power amplifier is commonly used in educational settings. Overall, while various methods exist, achieving precise frequency control remains a key consideration.
gavinthoms
What can be used as a Frequency generator to make chladni patterns?
Welcome to PF.
Chladni figures form on the surface of a resonant plate.
Striking the plate with a small hammer, or using a violin bow, will excite the plate.
If you use an electronic oscillator, you will need to adapt a speaker coil, or some similar transducer, to shake the plate. You may then have trouble finding the critical resonant frequency.
You could mount a small electric motor below the plate, with an unbalanced shaft, that would shake the plate at the motor rotation speed.
For school we use a vibration generator, which is like a speaker, and a signal generator with an audio power amplifier.
I expect that transducer is the same as the ones I used to have in my lab. They are pretty heavy duty and link to a suitable waveform generator over several octaves (from very slow upwards). Natural resonances are more easy to induce, as you say but the re-arrangement of the sand when passing from one mode to another is impressive.
That's one approach (as with a water wave generator) but the frequency control of that method (motor speed) tends to be associated with big amplitude fluctuations.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
