What causes water to oscillate at high temperatures in the Leidenfrost effect?
  • Thread starter Thread starter Tamerlane
The discussion centers on the Leidenfrost effect, where water droplets can hover on a surface at temperatures above 240 Celsius due to a vapor layer that forms between the liquid and the surface. The participants are investigating the oscillation of water droplets at around 410 Celsius, observing a frequency of about 10Hz and a unique triangular shape with multiple tips. They seek to understand the molecular movement within the droplet and the underlying physics, including the role of surface tension and potential formulas that describe these phenomena. Suggestions include exploring concepts like dipole-dipole attraction and vortex shedding to explain the observed behaviors. The conversation highlights a blend of experimental observation and theoretical inquiry into fluid dynamics.
Tamerlane
First of all, let me say that I'm a french [in the way that i speak french] student and most probably my sentences will not be as accurate as they should, excuse me in advance.
To make a long story short, the Leidenfrost effect makes a water drop to stop "boiling" at temperatures higher than 240 Celsius. The principle is as follows: the suddent heating of the water (when it falls on the surface) immediately creates a vapor layer between the liquified water and the surface.
Note: we have roughly measured the actual temperature of the water at around 80 celsius.
The same effect happens with a particular plastic surface that as been "polished" (or scratched) with an extremely thin sandpaper OR a surface covered with teflon => there is small "bubbles" of air that gets trapped between the real surface and the water.
Anyway, what interests me and my group is that when you heat the water ; our optimal temperature (for the oscillating mode we concentrated on) is about 410 celsius, at that point and from a very particular volume of water [the drop constantly evaporate], it starts oscillating at a frequency of about 10Hz and increasing. At that point, the drop has a rounded triangular shape, but it's so fast, you see 6 and arguably 8 tip to the "star" it forms.
Now, i'd like to know if anybody has ever heard of or work on such thing, we'd especially like to know what exactly happens, what makes the water turn on itself or oscillate [we're not even sure about the movement of the molecules within the drop]. If there is any formula that exists to describe such phenomenon or anything else.
Also, we are being told it has something to do with surface tension, anyone can help?
Thank you
Suface tension created by the dipole-dipole attraction of water molecules are the reason for this. however, you may want to try a chemistry forum for the answer.
Is this the definition?
LEIDENFROST EFFECT - Where a liquid will not wet a surface and becomes insulated from the surface by a layer of vapor if the surface is above a critical temperature of the liquid. The surface is usually well above the liquids boiling point. Water beads seems to last forever in a 400 F frying pan on a stove, where they would boil away in 5 seconds if the pan were only 220 F. McGraw Hill, Dic. of Sci. and Tech. Terms, 5th ed, 1994 (200,000 definitions in one book)
Thought posting the definition I use in my book "Effects and Their Uses" should be included here.
Steve Stillman
Steve: well...i already know that, I've been looking at those water beads for hours, but thanks anyway
2Pac: hmm...dipole-dipole attraction, that might be the answer...but do you think that would be enough to create a cross wave [now I'm really not sure if it's the right word, in french it's called "onde transversale" where onde = wave] and we observed 6 different modes of oscillation, we are currently studying the 4th mode because it's the one that we have the most facility to recreate
You are more likely looking at "vortex shedding" from a "bluff body" --- sorry, no French translation for you.
hmm, that sounds interesting, i'll look for that :)
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
