What chemical properties affect the specific heat?
In summary: These electrons can freely move between the metal atoms, and as a result they can contribute to the extra degrees of freedom. In general, the greater the number of conduction electrons, the higher the metal's specific heat.In summary, specific heat is influenced by the number of degrees of freedom that a substance has.
jaumzaum
434
33
Hello all! I would like to know what chemical/physical properties influencies the specific heat. For example, why are specific heat of metals smaller than the specific heat of water, and why do ice and steam have a smaller specific heat than liquid water do.
Science news on Phys.org
This short tutorial and video may answer your question:
https://courses.lumenlearning.com/boundless-physics/chapter/specific-heat/
As a substance like water is being heated (ie energy is added to the substance) it seeks to store the energy in various ways:
- kinetic motion of the molecules
- rotational speed
- vibration of bonds
- other modes of freedom
https://en.wikipedia.org/wiki/Specific_heat_capacity
Polyatomic gases[edit]
On the other hand, a polyatomic gas molecule (consisting of two or more atoms bound together) can store heat energy in other forms besides its kinetic energy. These forms include rotation of the molecule, and vibration of the atoms relative to its center of mass.
These extra degrees of freedom or "modes" contribute to the specific heat of the substance. Namely, when heat energy is injected into a gas with polyatomic molecules, only part of it will go into increasing their kinetic energy, and hence the temperature; the rest will go to into those other degrees of freedom. In order to achieve the same increase in temperature, more heat energy will have to be provided to a mol of that substance than to a mol of a monoatomic gas. Therefore, the specific heat of a polyatomic gas depends not only on its molecular mass, but also on the number of degrees of freedom that the molecules have.[15][16] [17]
Quantum mechanics further says that each rotational or vibrational mode can only take or lose energy in certain discrete amount (quanta). Depending on the temperature, the average heat energy per molecule may be too small compared to the quanta needed to activate some of those degrees of freedom. Those modes are said to be "frozen out". In that case, the specific heat of the substance is going to increase with temperature, sometimes in a step-like fashion, as more modes become unfrozen and start absorbing part of the input heat energy.
For example, the molar heat capacity of nitrogen N
2 at constant volume is {\displaystyle c_{V,\mathrm {m} }={}}
20.6 J/K/mol (at 15 °C, 1 atm), which is 2.49{\displaystyle R}
R
.[18] That is the value expected from theory if each molecule had 5 degrees of freedom. These turn out to be three degrees of the molecule's velocity vector, plus two degrees from its rotation about an axis through the center of mass and perpendicular to the line of the two atoms. Because of those two extra degrees of freedom, the specific heat {\displaystyle c_{V}}
c_{V}
of N
2 (736 J/K/kg) is greater than that of an hypothetical monoatomic gas with the same molecular mass 28 (445 J/K/kg), by a factor of 5/3.
This value for the specific heat of nitrogen is practically constant from below −150 °C to about 300 °C. In that temperature range, the two additional degrees of freedom that correspond to vibrations of the atoms, stretching and compressing the bond, are still "frozen out". At about that temperature, those modes begin to "un-freeze", and as a result {\displaystyle c_{V}}
c_{V}
starts to increase rapidly at first, then slower as it tends to another constant value. It is 35.5 J/K/mol at 1500 °C, 36.9 at 2500 °C, and 37.5 at 3500 °C.[19] The last value corresponds almost exactly to the predicted value for 7 degrees of freedom per molecule.
The different heat capacities for the different phases of water (or any substance) comes in great part from intermolecular forces, which different greatly in the different phases. Crystals posses vibrational degrees of freedom which are not present in the gas phase.
Metals are also special because of the presence of conduction electrons.
Related to What chemical properties affect the specific heat?
1. What is specific heat and why is it important?
Specific heat is the amount of heat required to raise the temperature of one gram of a substance by one degree Celsius. It is an important property because it determines how much energy is needed to change the temperature of a substance, which can impact various industrial and environmental processes.
2. How do chemical properties affect specific heat?
Chemical properties, such as molecular structure and bonding, can affect specific heat by influencing how tightly the molecules are packed together and how easily they can vibrate. This, in turn, affects the amount of energy needed to change the temperature of the substance.
3. Which chemical properties have the greatest impact on specific heat?
The molecular weight and composition of a substance have the greatest impact on specific heat. Substances with heavier molecules or complex molecular structures tend to have higher specific heats, as they require more energy to change temperature.
4. How does temperature affect specific heat?
Temperature does not directly affect specific heat, but it can indirectly impact it by influencing the molecular movement and bonding within a substance. Higher temperatures can lead to more molecular movement, which can decrease the specific heat of a substance.
5. Can specific heat be changed or manipulated?
Specific heat is an intrinsic property of a substance and cannot be changed or manipulated. However, it can be influenced by changing the chemical composition or structure of the substance, as well as external factors such as temperature and pressure.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
