What Consumes Fewer PC Resources: 1 Window with 250 Tabs or 5 and 50
Using a single window with 250 tabs open is generally more resource-efficient than having five separate windows with 50 tabs each. This is because each additional window consumes more system resources for management and rendering. Grouping tabs can help optimize resource use, as only the tabs in the active group will load, reducing overall memory consumption. Restarting the browser can also refresh resources, allowing only the selected tabs to load when accessed. Therefore, managing tabs effectively by grouping and minimizing open windows can lead to better performance on a Windows 10 PC.
WWGD
TL;DR Summary
Hi, just want to cut down on resource use in my Win 10 PC browsing.
Is having one window open with , say, 250 tabs open [preferable to 5 open Windows with 50 tabs each?
As a rule of thumb, Is having one window open with , say, 250 tabs open preferable to 5 open Windows10 Windows with 50 tabs each?
What setup would consume more resources? I understand there's o hard and fast rule, but any rule of thumb?
TIA.
Computer science news on Phys.org
Doesn't directly answer the question, but are you using all those 250 tabs at once? If not, it might help to group them (both in Chrome and Firefox), and then clearing all browser cache and restarting the browser. Then just click on the tab groups you need. Other groups won't be loaded unless you visit them again.
I have 256 tabs open, and have grouped them separately. I open each group in a separate window when necessary.
Isn't it as simple as comparing 250 tabs + 1 window vs 250 tabs + 5 windows? 4 windows more to manage in the latter case?
If you have multiple tabs open, close and restart the browser, each tab will reload only when you select them as well.
Likes WWGD and Wrichik Basu
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
