What determines the colour of chromium compounds?
In summary, the conversation discusses the processes through which cations are colored in ligand complexes and the interaction with aqueous mono-atomic cations. The speaker is interested in the specific colors of chromium and its compounds and how they are affected by the interaction with photons and atomic orbitals. They believe that the color of chromium is solely dependent on the separation of its d-orbital and not influenced by other elements. It is noted that ligand field theory also applies to solids and that in many complexes, the color is mostly due to charge transfer transitions from the ligand to the metal.
24forChromium
155
I am aware of the processes through which cations are coloured in ligand complex (splitting of incomplete d-shell will absorb specific frequencies of the spectrum). However, I am only aware of this interaction with aqueous mono-atomic cations, which is not always a present condition when colours are present in substances.
I am interested specifically in chromium and its compounds' colours, I would like some explanation in terms of interaction with photon and atomic orbitals for the various colours chromium has, and ultimately to narrow done the exclusive causes responsible for chromium's compounds' colours.
I currently believe that the colour of chromium is only dependent on the separation of its d-orbital and unrelated to any other present elements, other elements only serve to modify its d-orbital but does not interact with photons meaningfully themselves.
Chemistry news on Phys.org
Just some remarks:
- Ligand field theory is also applicable in solids.
- While ligand field theory explains quite well the wavelength at which d-d transitions occur, these are often not the most intense absorptions present in a compound, as they are dipole forbidden. Rather, in many complexes, the colour seen is mostly due to charge transfer transitions from the ligand to the metal.
Related to What determines the colour of chromium compounds?
The colour of chromium compounds is determined by the arrangement of electrons in the outermost energy level of the chromium atom. This is known as the d-orbital configuration and it plays a crucial role in determining the colour of chromium compounds.
How does the d-orbital configuration affect the colour of chromium compounds?
When a chromium atom is in its ground state, it has three unpaired electrons in its d-orbital. These electrons can absorb energy from light and jump to higher energy levels, causing the compound to appear coloured. The specific arrangement of these electrons determines the specific colour of the compound.
Why do some chromium compounds appear different colours?
The specific arrangement of electrons in the d-orbital of the chromium atom can vary depending on the specific compound. This results in different energy levels being available for the electrons to jump to, which in turn causes the compound to appear a different colour.
How do factors such as ligands and oxidation state affect the colour of chromium compounds?
Ligands and oxidation state play a significant role in determining the colour of chromium compounds. Ligands can affect the arrangement of electrons in the d-orbital, while oxidation state can change the number of unpaired electrons, both of which can alter the colour of the compound.
What other factors can influence the colour of chromium compounds?
Other factors that can influence the colour of chromium compounds include the presence of other metals in the compound, the concentration of the compound, and the physical form of the compound (e.g. solid, liquid, or gas). These factors can all affect the way light interacts with the compound, resulting in a different perceived colour.
10K
  • Chemistry
25K
