What Determines the Direction of Acoustic Radiation Force?
  • Thread starter Thread starter SFB
    Acoustic
The discussion centers on understanding the acoustic contrast factor and its role in determining the direction of acoustic radiation force on particles in sound waves. The sign of the acoustic contrast factor influences whether particles are pushed toward pressure nodes or antinodes. The physics behind this involves the compressibility of the particle and the medium, affecting the particle's movement in response to the radiation force generated when acoustically activated. The concept of iso-acoustic focusing is suggested as a way to simplify the understanding of particle movement in a microchannel. Overall, the interaction between sound waves and particle properties is crucial in predicting the behavior of particles under acoustic forces.
SFB
Hi
I have some confusion in understanding the acoustic contrast actor . You can check wiki if you are not familiar with the term.
http://en.wikipedia.org/wiki/Acoustic_contrast_factor
If there is a foreign particle in the path of a sound wave (to be specific Standing wave for my case), the sign of acoustic contrast factor determines whether the acoustic radiation force will push the particle toward pressure nodes or antinodes.
As the radiation force is a function of acoustic contrast factor , mathematically sign of the contrast factor determines the force direction.
But I am interested know the physics behind it. How the compressibilty of the particle and medium of propagation determines the direction. What actually happens when sound waves confront a compressible bubble or an incompressible rigid particle ?
I tried to trace some resources , but they are full of mathematics as well.
I would appreciate if you can kindly share your opinion in this regard.
Thanks
, it is quite obvious mathematically that a
Hi,
I would look up Iso acoustic focussing of particles, this would make this concept easier.
Basically the movement of a particle in a microchannel will either be positive (inwards to the centre) or negative (outwards to the sides).
This depends on both the compressibility and density of the particles, when acoustically activated a radiation force F(rad) is generated.
The particle will move to a point where acoustic impedance matches that of the medium.
Hope this helps
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
