What device would I need to send data over power lines?
In summary, a home-based system that uses coded pulses to control devices using AC power would require a controller and switch units, three sub-units, and home wiring. Alternately, a product called X10 which is still available can be used to transmit signals over the power lines.
TechTree
32
Hello, I'm trying to send binary data over the power lines to a microcontroller, which triggers a relay turning on a light. I was wondering what kind of device would I need to use to achieve this? And how would I connect it up to the microcontroller? I'm fairly new to this, so if someone could point me in the right direction I'd be grateful.
Many thanks! :wink:
Radio Shack sold a controller and switch units for home use called "Plug and Power" or something similar. I experimented with three sub-units for lamps (2-prong connection), small electric fans, and "heavy-duty" 3-prong (grounded) AC connection. Units communicated through home wiring using coded pulses. End user rotates a dial labelled alphabetically on the control unit and each sub-unit with the idea of avoiding another user's signals. I tried the original version and an improved design released mid 1990's.
Though a nifty idea -- remote control via AC power lines -- long term experience was negative. As might be expected, the fan or "small motor" switching unit had numerous problems, some apparently frequency related. Relay chatter was common, causing odd conditions to the plugged in device. All sub-units displayed intermittent behaviour, often switching states when another sub-unit was switched by command. After my bedside reading lamp switched on at 0300 (3AM) unrequested, I removed the units from service.
From time-to-time I would unpack the system when I needed temporary "remote control". It always disappointed.
I found the user manual online from a related product: https://www.manualslib.com/manual/137971/Radio-Shack-Wireless-Remote-Control-System.html?page=6
Likes TechTree
@Klystron had the right idea if the question relates to use in the home (as opposed to sending signals across the continent). The popular product went under the brand name X10. It is still sold, and many modules are available.
https://en.wikipedia.org/wiki/X10_Wireless_Technology
Likes Klystron
Yes, I assumed home use since this is DIY but found interesting references using the power grid to carry messages. https://en.wikipedia.org/wiki/Power-line_communication
We'd expect the power distribution companies to transmit data over the power lines, presumably related to the transmitted power, but the Wiki articles indicate an "Ethernet-like" encapsulation of information packets among other data transmission models.
For the general case "transmission line" the OP might be interested in time domain reflectometry (TDR) developed at HP originally to locate (physical) breaks in electrical lines; but useful in this case for determining conditions for data transmission on a given line. https://en.wikipedia.org/wiki/Time-domain_reflectometry
I think one option would be to get it working over Ethernet first using network/web relays...
You can buy them..
https://www.controlbyweb.com/webrelay/
Or perhaps roll your own..
https://randomnerdtutorials.com/arduino-ethernet-web-server-with-relay/
Then use other standard devices (Powerline) to send the network over the mains.
This would be safe, but perhaps more expensive. An advantage would be the web relay has a website built in so you can interrogate the status of any lights remotely form anywhere in the world.
Likes TechTree
FAQ: What device would I need to send data over power lines?
What is Power Line Communication (PLC)?
Power Line Communication (PLC) is a technology that allows for the transmission of data through existing power lines. It utilizes the electrical wiring in buildings to send and receive data signals, eliminating the need for additional cables or wireless networks.
What type of device is needed for PLC?
A device called a PLC modem or adapter is needed to send data over power lines. This device connects to the power outlet and to the device that needs to send or receive data.
How does a PLC modem work?
A PLC modem works by converting digital data signals into high-frequency electrical signals that can be transmitted over the power lines. These signals are then received by another PLC modem, which converts them back into digital data.
What are the advantages of using PLC?
The main advantage of using PLC is that it utilizes existing infrastructure, so there is no need for additional wiring or equipment. It also provides a secure and reliable connection, as the data is transmitted through the power lines within a building.
Are there any limitations to using PLC?
One limitation of PLC is that it may be affected by electrical interference from other devices or appliances. It also may not be suitable for long-distance or outdoor applications, as the signal may weaken over long power lines or outside of a building's electrical grid.
10K
