What do the markings on a capacitor mean?
  • Thread starter Thread starter justlearning
    even
The markings on the capacitor indicate it is likely a multi-layer ceramic capacitor with a capacitance of 1000 pF, where "102" represents 10 x 10^2 pF. The "100" likely refers to its voltage rating, possibly 100 VDC, while "NCC" may denote it as a normal chip component. The "K" could imply a tolerance of 10%. The undistinguishable mark might represent a specific product line code.
justlearning
I have a capacitor that is marked different than most I've run into in the past. I'm not sure how to read it. It looks exactly like this:
K*E
102
100
NCC
Where the "*" is there is an undistiguishable mark. possibly a "N" inside a circle. It's printed exactly like that on a reddish brown if that helps. I believe it's a thin film polyester cap. Can anyone help me identify it?
I realize this is way below everyone's knowledge base here. I am not an electrical engineer btw.
Also my guess is 10 x 10 to the second power, and 100 degrees C
Maybe 100 can also be the maximum applied voltage of the capacitor.
102 I agree with you, 10*10^2 nF.
1nF 100V most likely.
102 usually means 10 * 10^2 pF
You could educate yourself on capacitor marking by brousing through a capacitor manufacture's data sheets.
The capacitor is 1000 pF (as uart noted), the '100' is a voltage rating. This could mean 100 VDC or a code for some other voltage. NCC mean 'normal chip component' in some cases. So it's probably a multi layer ceramic. The first line is probably a code for the general product line.
There is no tolerance given that I can see, except the first 'K', so I assume this is implicit in the product line code or K means it a 10% part.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
