What Do Vertical Lines in Signal Graphs Represent?
Vertical lines in signal graphs serve a specific purpose in visualizing data points. In discrete time continuous value signals, these lines help indicate the time at which each value occurs, enhancing clarity. For continuous time discrete valued signals, the vertical lines represent jumps between values, while the actual signal is depicted by horizontal segments. Discrete time signals arise from sampling continuous signals, and discrete value signals result from quantizing continuous values. Understanding these representations is crucial for grasping the fundamentals of signal theory.
Bassalisk
So I am 2nd year now and we started this new course Theory of Signals.
Already I bumped into a wall when it came to understand basic stuff.
Here is what I mean
[PLAIN]http://pokit.org/get/0864633c869b647116b980428a07d4f1.jpg
Here we have 4 functions, each representing one type of signal.
1st one I understand. Its a continuous function, defined at every point.
2nd one reminds me of a plotted sequence. But the thing that confuses me is that vertical line connecting abscissa and the value of the signal.
Does that line represent something? Or is it just for visual purpose?
Same question for the 3rd graph. It is even more confusing. It goes zig-zag. Again what do those vertical lines connecting 2 parts of graph represent?
These are the four types of signals:
1st one you got right, continuous time continuous value
2nd one is a discrete time continuous value. The lines are just there to make it easier to see at what time each point represents. In MatLab you make those plots by using stem(x,y).
3rd one is a continuous time discrete valued signal. The vertical lines just represent a jump from one value to another. The signal really is just the horizontal lines, but when you plot it the software connects the data points so you get those jumps.
4th is a discrete time discrete valued signal.
Discrete time signals can be obtained by sampling continuous time signals.
Discrete value signals can be obtained by quantization of a continuous valued signal.
Thank you for clearing this confusion for me. I just finished with my math class and I still have my math goggles on. That is why I found this confusing.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
